toyota
Tune Up?? any DIY !!
i cant seem to find a diy for how to tune up our yaris..unless were just replacing the plugs after 100k ??
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
The best thing you can do is to run a good fuel system cleaner every 5,000 to 10,000 miles. Cleaning out the fuel system and injectors will keep the car running smoothly.
Audio Junky
or just pay the extra 2cents a gallon for good gas (like chevron)... and you'll have nothing to worry about.
#4 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
![]() So, back to my question, will using better gas clean the injectors over time or should I use something else? And if so, what should I get? Anything from the gas station or is there some secret power potion?
#5 | |
Learn to Relax
The real secret is to do regular prescribed maintenance. Anything more than that is because you love your Yaris. |
#6 | ||
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
And as fuel system cleaners are formulated into the gas at the pump i'll also agree with posaunemeister that any kind of fuel additive is a waste of money,you'd get better return on money by buying wife/mom/girlfriend a bunch of flowers and then taking them out for supper
#7 | |
Learn to Relax
Change the plugs and air filter and the transmission oil if you have a manual. Get to know the parts of the car that are inspected like ball joints, CV boots etc.
toyota
cool..i guess this modern cars dont need timing readjustment... fuel line cleaner sound good..
#10 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
I'll put money that using fuel cleaners every 5,000 miles will result in you replacing a fuel filter or pump before you would get any buildup had you never used cleaners. |
#11 | |
Also, last time out I put Sunoco Ultra in to see how it runs...GREAT!
Never take eyes off opponent - Bruce Lee |
![]() ![]() Drives: 2008 Yaris S LB - MM Join Date: Aug 2009
IMHO, fuel injector cleaners are a waste if being used in new(er) cars, i.e., anything younger than 3yrs old or has less than 36K miles. Frequent use of cheap gas and air filter malfunctions are variables to be considered, of course.
#13 | |
Learn to Relax
#14 |
Learn to Relax
#15 |
Fuel filter? Where is this on the sedan? And how many miles before you change it?
#16 |
#17 |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
i'd run a full injector cleaner after about 50k miles and be done with it till 100k. u can gtet a shop-air operated fuel system cleaner from mac/matco/snapon. and you might be able to get one from autozone.
any way, pull out fuel pump relay or fuse (pref fuse if it's easy), run car till it dies. pull fuel line and find adapter for the tool. insert and install tool adapter, connect to tool. fill tool bottle up with supplied cleaner or cleaner of your choice. supply air feed to bottle. set to standard fuel pressure. most EFI engines are between 35 and 55psi. start car, LET IDLE until car dies again...remove tool, reinstall fuel lines and fuse. you're done. is it a pain? yeah, but it works much better than those cheesy knockoff fuel system cleaners. |
#18 |
toyota
i guess the main key points here is fuel cleaner will definetely clean the lines but gunks has to go somewhere and thats where to fuel filter is for i guess if it gets full it need to be replace.. so do fuel line cleaner then replace fuel filter..while ur at it change ur oil and air filter...
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 11:48 AM |
| revamping the DIY section | supmet | Suggestions - Feedback - Questions | 7 | 03-23-2009 02:01 AM |
