![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
DIY Camera Mount
Anyone who has seen my in car videos and wandered how i mounted the camera well here it is, cost for me was nothing at all. And it is super easy to do, just maybe time consuming if you dont have the necessary bit size
Items Needed: Tripod with height extension (the ones that you can raise the camera up/down) Drill 1/2 inch drill bit Steps: Drill 1 or 2 holes on the pipe to thread the head rest through, i chose 1 cuz it was hard enough to do one (i did not have a 1/2 in bit and instead of buying one i just bore the hole out with a 1/4) not to mention it will be hard to match 2 holes perfectly. And that ends the steps.. easy huh? Notes: measure where to drill the hole to center the camera between the front two head rests. by using a tripod mount, you get vertical and horizontal axis movement for adjustment. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
thats pretty chill this works good too like 10 15 buggs
Is that on the driver side or the passenger side? I made my like that so i could have it on driver side, passenger side results in lots of adjustments after each time the seat has to move.
| Any interest in a universal headrest camera mount? | PlaidBear | Cosmetic Modifications (Exterior/Interior) | 26 | 11-16-2009 12:38 PM |
| DIY Camera Mount -- No Cost Version | KCALB SIRAY | DIY / Maintenance / Service | 20 | 06-08-2009 03:12 PM |
| Camera mount in action | m911gt | Photo-Video-Media Gallery | 43 | 02-04-2009 03:50 PM |
