Old 11-08-2009, 04:02 PM   #1
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
Triple C Design pod finished and installed
here we go, the moment we all been waiting for.
Triple C design: Model "T1G2"
Sample getting ship to Garm on monday and we are just waiting for approval.
cruz-gsr is offline
Old 11-08-2009, 04:39 PM   #2
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
awesome!
kac is offline
Old 11-08-2009, 04:43 PM   #3
anubisx99
here again..
anubisx99's Avatar
Drives: 2008 toyota yaris LB
ok, for the install we'll be making a DYI and we'll also include it with the pod, video will be up soon..
Don't be threating me with a good time!!!
anubisx99 is offline
Old 11-08-2009, 05:00 PM   #4
bobselectric
Kickin' Yaris
bobselectric's Avatar
Drives: 07 Yaris liftback
meh- looks really bulky, and I wouldn't want to lose the glove box
bobselectric is offline
Old 11-08-2009, 05:13 PM   #5
cruz-gsr
cruz-gsr's Avatar
you can still use the box, the door does not open all the way but can still storage stuff there.
cruz-gsr is offline
Old 11-08-2009, 09:43 PM   #6
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
+1
losing the glove box would be something I wouldnt do considering I use the toll 4 times a day
TinyGiant is offline
Old 11-08-2009, 10:47 PM   #7
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
+2. This showed much promise, but I'm not too crazy about that size blocking the door and having to cut into it for the center gauge. Originally I was thinking you were building an exact replica of the one in the pics I posted in the initial thread. Sorry guys, have to pass on this (at least until it's redone)
SilverBack is offline
Old 11-09-2009, 12:15 AM   #8
anubisx99
here again..
anubisx99's Avatar
as far as the hole, in the middle, I have explain this many times, the hole WE have is from our old setting, the holder is made to fit everything WITHOUT cutting into the cover, the original TRD (the one you got pics Krayzee) is closer to the glove compartment and I can guarantee you for that you'll HAVE to cut into it to make everything fit (unless the TRD gauges/tach is less than 1" deep, doubt it)...
Old 11-09-2009, 12:39 AM   #9
SilverBack
Joey
SilverBack's Avatar
K I see what your saying now. What if you could just lengthen the center gauge section an inch or two so it's right above the steering column? There's plenty of dead space between the door and the wheel, and it should allow you to shrink the back of the pod just enough to open the door fully. What do you think?
Old 11-08-2009, 06:22 PM   #10
advocate
Drives: car
Can you fire up the car and drive it around so we can see this in action?
advocate is offline
Old 11-08-2009, 06:28 PM   #11
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Ugh, it looks so good. (I'm annoyed because the TRD gauges by Defi are so expensive. ;_; )
FYI I believe even the factory pod installs with bolts. Four of them IIRC.
Gideon is offline
Old 11-08-2009, 06:42 PM   #12
anubisx99
here again..
anubisx99's Avatar
my friend, my next project should take care of your (and my) problem...
'nuf said!'
Old 11-08-2009, 06:39 PM   #13
anubisx99
here again..
anubisx99's Avatar
yes, we'll make a video for the install (just as before), we'll have the tach installed, as far as the other gauges there's a few things to keep in mind:
1-depending on the user gauges may be different
2-installs are also different by the user, one may installed different than others
3-the pod function is only to give the user the placement for whatever gauges they need/want, VAC, TEMP, PRESSURE etc...
for these many variables the gauges that are there are just for you to have a good idea of the final look, also AND THIS IS VERY IMPORTANT:
different gauges/tach brand have different depth so, the pod was build to hold certain max depth anymore than that and you'll have to "cut" the door to fit them, in the install pics/videos we'll go over everything...
next question...
Old 11-08-2009, 06:30 PM   #14
anubisx99
here again..
anubisx99's Avatar
the pod will be shipped without any holes, that way for those who want to "hot glue it" they can, as far as the bolts, 1- the original (see: http://www.yarisworld.com/forums/sho...t=23584&page=2) it uses 4 instead of 2, 2- they are not that big once it's all together and 3- this is our first model as we go I'm sure better ideas on how to install it will come out, also as far as still be able to use the compartment, you can, you can install the pod as low as touching the steering column, the lower it goes the more the door will open, it's that simple....
next question...
Old 11-09-2009, 01:58 AM   #15
I think a poll is in order to see if opening the door is something the majority of possible customers would want. I put my gauges into that area and I've never missed that little storage space.
cali yaris is offline
Old 11-09-2009, 03:09 AM   #16
advocate
Drives: car
I use it to store things for work but only because I can, not because I have to...
advocate is offline
Old 11-09-2009, 04:09 AM   #17
SilverBack
Joey
SilverBack's Avatar
I need that space to hold things I would need access to right away if needed like insurance and reg. cards, change, my workout gloves, spare business cards, and sometimes anything that I need to hide from nosy but clueless passengers.
Old 11-09-2009, 06:57 AM   #18
bobselectric
Kickin' Yaris
sorry, didn't mean to flame- I think you guys did a great job designing this, and the unit looks to be first rate. Just not my cup of tea, sorry
