![]() ![]() Drives: 2008 Sedan White Join Date: Oct 2008
30,000 mile service, this should get you going
So I'm trying to get the dealership to do a 30K warrantee service.
They wanted to do some plan D or something. 305 bucks. I told them I didn't have an auto trans so they dropped it down to $239. Then I started with what do you do? Change the fluids in the radiator, engine, and tranny. inspect this and that. So I go out to my car and get the warrantee book and say I want this done as per my manual at 30K. 29.95 WTF? The guy there said "Oh it looks like an oil change to me" they check all the other stuff normally. So I don't need my trans oil or radiator fluid changed. I have a K&N Filter. What's right? I called another dealer (where I bought the car) and they wanted 329. I asked the girl that got my lucky call why are you trying to do all this stuff. Of course she doesn't have a clue. referred me to another rep that never called back. I tried searching for similar threads here with no luck. Someone must have come across this before. |
yaris requires no services till 100k its just all oil changes.
![]() Drives: 207 yaris sedan Join Date: May 2009
Maybe different north of 49th??
My 07 Sedan's service schedule requires a 32,000 km maintenance service..mostly changing fluids, filters, tire rotations, brake inspects, road test...230 bucks plus (Can.) vs 39 for the oil changes at my dealer!
Is "Plan D" their actual name for it? Let me know, my roomate is a toyota tech and he will give me the lowdown.
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
It's a well-known fact that new-car dealerships hose people on services with fake "needs", to make up the lack of profits on new vehicles. That is, they add service-stuff that isn't required. That's how they make their money. I think this is why I initially stopped coming on YW, too many ignorant folks that get taken by the dealer, then come on here to vent, or comes on here venting about the dealer ripping people off. It's a blatantly obvious fraud, but dealerships need to survive somehow.
I also don't feel bad in the least bit for any sucker that gets taken by them, either. The very first thing you should do after buying a brand new car is to read the manual: All the service intervals and requirements are listed in there. Last edited by tomato; 11-17-2009 at 04:39 PM. Reason: no need for that |
#6 | |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
Sorry your YW experience hasn't been what you expected, but the OP couldn't care less about that. ![]() You make a valid point, but it would be so much nicer if you could just say what you need to say without the negative tone, eh? All questions are welcome. Not everybody is an expert at everything, and if people need help and want to ask the community, that's what forums are for! Be nice!
#7 | |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
#8 | |
Like I said, I don't disagree with the message, just the tone. ![]() Nice avatar BTW, silky smooth, I get it
#9 | |
from 'you dont mess with the ZOHAN' as is thesilkysmooth hair creme' application reference Last edited by TheSilkySmooth; 12-03-2009 at 03:00 PM. Reason: clarify |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
The old school is slipping away. To actually open a book and do your own research is becoming a thing of the past.
Making a decision without following it with an action is still a fantasy. |
#11 | |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
Also it's not fraud, as long as they do what they claim they will. Also a lot of people do these things early anyway. Nor is it just dealers: my brother had a quick-lube type place suggest that they change his diff fluid too (not a yaris) and that the manufacturer suggested such and such oil. His response was "the manufacturer also suggests not doing it for 40k more miles. |
#12 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
Even if they do a service that they claim is required, if the service is not needed, THAT IS FRAUD! Obviosly in order to get a customer to okay a service that is not required, lying is required, so therefore, it is in fact fraud. |
#13 | |
![]() ![]() Drives: Hatch Join Date: May 2009
#14 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
#15 |
![]() ![]() Drives: 2008 Yaris HB Join Date: May 2009
Not so fervent but I would have to agree I have yet to meet a Toyota service advisor who knows more about my car than I do.
Oil and filter changes, with air cleaner replacement (or cleaning with my K&N) is all this car needs for many miles. Changed the MT oil with MT-90 at 15k, and the usual tire rotation and rear brake adjustment. Spark plugs, coolant, do not need changing before 100k. Neither does the timing belt. There is nothing to lube on the chassis or suspension either. These cars are simple, don't waste your money at the stealership unless there is a problem. Out of the 20 or so cars I have owned at one point or another over the years this car has got to be the EASIEST car to change the oil on. Literally takes 5 minutes. During one of those I found an axle seal leak, which was fixed under warranty, dealer treated me right and did it in one day. I will return to them for future warranty work, I found a good dealer going to stick with them but only for the absolute minimum work. |
#16 |
H3LlIoN I'll let you know when I get my oil changed.
I understand the dealers have to make money. Just not why 10 times as much. Toyota . com is getting back to me on the differences, too. Thanks guys! |
#17 |
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
It's very simple with these cars. The reason that they are so great is that for a mere $14K, you get a car that you get inside of and go until something becomes unsafe, noisy, unstable or it is noticibly running poorly. These cars are made to be disposable/consumable ecoboxes so DON'T touch them unless they call for it. Just change the oil frequently and you will have a car that goes forever!...and ever....and ever.
#18 |
H3LlIoN, I don't know if it's called plan "D" or what, they have a sheet of paper with four service schedules on it. It's the one with the tranny flush @ 30K if you have a auto which I don't. I think I'm going to do this one myself with some Redline or Amsoil in the manual and crankcase. I contacted Toyota . com they received the emal but no response yet. Does this help you out?
| Why does 15000 service cost so much more than 5000 and 10000 mile service? | monyaris | DIY / Maintenance / Service | 7 | 06-25-2009 07:12 PM |
| 5000 mile (8000 km) service due, what is to be done? | kenora | DIY / Maintenance / Service | 3 | 06-25-2009 05:46 PM |
| 10,000 mile service | lindstothek | DIY / Maintenance / Service | 7 | 01-21-2009 01:42 PM |
| 30,000 mile service: owners manual vs Dealer "recommendations" | yaristotle | General Yaris / Vitz Discussion | 7 | 11-20-2008 10:41 AM |
| 30,000 mile service: Dealership or non-dealership? | EstherK | DIY / Maintenance / Service | 1 | 11-12-2008 12:40 PM |
