Old 11-25-2009, 04:11 PM   #1
Badger
Drives: Yaris 1.33
Yaris Throttle over-revs changing up
My dealer says this is 'normal' but I drive 4 different cars at weekend and I've never seen this before. When changing up 1-2, 2-3 as soon as the clutch is depressed the engine over-revs, not every time but around 20% of gear changes. This happens both cold and hot and has done same in higher gears but not so frequent. I've tried various driving positions but it still happens. I've been VERY careful about releasing throttle to no avail - this did not happen during my 1 hour test drive (I'm going to visit dealer to try another demo car).
Mind you my dealer also says the stop-start system works by disengaging the flywheel!!!
Is this really 'normal' for a 2 month old Yaris? or is this 'normal' for dealers only
Badger is offline   Reply With Quote
Old 11-25-2009, 04:19 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Take your foot of the gas pedal sooner , thats why it does not do it on down shifts , because your right foot is on the brake .
Old 11-25-2009, 06:25 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
I have had friends drive my yaris before. They often rev'ed it up on an up shift. (ie, 1-2, 2-3)
This had happened to me when i did the test drive before i bought my yaris, and also happened when i first got my yaris. At the time, i already knew about the drive-by-wire thing, so i adjusted my foot according to the response time of the throttle.
Driving different cars does not mean you are driving the yaris properly. Try lifting your foot off the throttle a fraction of a second earlier than you usually do as you depresse the clutch
Old 11-26-2009, 02:14 AM   #4
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
I see you're the only Yaris that's been affected by Toyota's "stuck gas pedal" recall
I had this rev problem until I decide to let off the gas completely a full second before shifting. Just take it slow and easy.
Old 11-26-2009, 10:03 AM   #5
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
+1, I can see why OP is wondering however. just takes getting used to.
Old 11-26-2009, 06:13 PM   #6
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I have the same problem with some over revving when shiftingthink it has something to do with fly by wire throttle i just live with it,suppose i could take my foot off the gas a few seconds before disengaging the clutch if i thought it was a big deal..
Old 11-27-2009, 01:27 PM   #7
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
yup, this just takes getting used to, I don't think it has anything to do with the fly by wire. I think it's just a small 4 banger thing from my experience (hyudai elantra did it before getting used to it), manual cars with bigger engines I've driven don't do it unless you are in too high of a gear and trying to accelerate.
BuildCode is offline   Reply With Quote
Old 11-28-2009, 02:25 AM   #8
Richie76
Drives: Toyota Yaris 07
I thought it was an emissions thing.. Our V8's over here with the fly by wire do the same thing... It's something to do with helping burning the excess fuel when lifting off the throttle..
Richie76 is offline   Reply With Quote
Old 01-01-2010, 02:33 PM   #9
Badger
Drives: Yaris 1.33
thanks to those who have responded, I've done some experiments. I can get over revving with no foot on throttle (just crash out of gear and push down on clutch to go up gear. it seems to be something in the ECU that's being kicked off when it senses a gear change
I'm not talking a 200 RPM increase, we're talking 500-1,000 RPM change. 200 is what I would call normal with my other young cars with similar technology. Most of my gear changes are at low revs, there is hardly any over -revving when changing gear at 4K or above. Richie76 may have nailed it with the emmisions thing, Another of my (2 year old) cars will flood if driven < 20 feet (like taking out of garage). It was explained to me that modern cars have a much more 'sealed' fuel system recycling unburnt vapours back into injectors/carbs rather than the old enging/exhaust/athmosphere system
Old 08-20-2014, 08:39 PM   #10
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
500-1000 rpm is really excessive! My '10 does it, but certainly not to that extent. Have the dealer or your mechanic test drive it with you in the car as well. Just a stupid question (sorry): you're not a beginner clutch driver, are you? Just saying that sometimes beginners stay on the throttle too long, or simply do not have the coordination for the clutch/throttle down pat, and it may appear that your engine is over-revving because of it.
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 09-05-2010, 07:13 PM   #11
09SedanPolarWhiteMT
09SedanPolarWhiteMT's Avatar
Drives: 09 Sedan, White, 5-spd MT.
Happens to me too, I thought it was the weirdest thing in the world when I first noticed it. Is it because of the drive-by-wire or something?
09SedanPolarWhiteMT is offline   Reply With Quote
Old 09-05-2010, 07:45 PM   #12
kou
Drives: 08 lb
It happens to keep the revs up between shifts.be worried when it revs to 7000rpms by itself.
Old 09-05-2010, 08:28 PM   #13
mine never did that
Old 09-05-2010, 10:18 PM   #14
RedRide
RedRide's Avatar
Mine never did it either.
In fact I never experience any problems with the DBW throttle.
Old 09-05-2010, 11:47 PM   #15
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Hm. I have had the same problem, and both the DBW and the emission control explanations make sense to me. I truly hate the Yaris throttle, not only for the over-rev, but because the throttle is so damn light: on long trips it gives me shinsplints, even after 3+ years. If I thought I could put an honest spring in the system for throttle feel (my buddy's Echo comes to mind), I certainly would!
Old 08-08-2014, 03:20 AM   #16
xyntax
Drives: Toyota Yaris Sedan YX
have the same problem. just changed the oil pressure control valve.
xyntax is offline   Reply With Quote
Old 08-08-2014, 10:45 AM   #17
sheekeebut
Minimalist
Drives: 07 silver sedan
I noticed the same thing when I went from Civics and Integras to Yaris.
I thought it's due to such an early version of the drive by wire, combined with the throttle response of an economy tuned engine.
I needed about 2000 km of driving to finally get a feel for the pedals. Realized mainly I was seated too close to the pedals. Backing off my seat allowed quicker clutch (dis)engagement, and lighter throttle manipulation.
sheekeebut is offline   Reply With Quote
Old 08-09-2014, 01:33 PM   #18
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
I think about making a video of me driving with mine, shifting fast is quite easy and it does not rev up at all.
It simply keeps up the RPM for a fraction of seconds, of course the engine revs up if the load is reduced (by disengaging) and the throttle angle stays the same :P
I drive, therefore I am.
dj92 is offline   Reply With Quote
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
What the Yaris community needs to take the Yaris to the next level regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 124 04-30-2009 02:03 PM
