Old 11-27-2009, 09:40 AM   #1
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
painting my car
I'd like to put a white frost over my blue car. Maybe 25% white fading from front to back and top to bottom. The effect would look like the car flew through an icey cloud and sat out in a heavy frost. Anyway, any ideas how to get this done either by myself or Maco or a similar place. I got a qoute of 4k which at a very reputable place which, until I sell a lot of oil, just ain't gonna work.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 11-27-2009, 11:40 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Why not see if vinyl graphics can do the same thing. It would be a lot cheaper and removable when you get tired of it.
Old 11-27-2009, 02:27 PM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
+1 I'd go this route. Even if it's pricey, it's worth being able to undo it. You never know when you'll be tired of your "icy" Yaris.
Old 11-27-2009, 02:30 PM   #4
supmet
Drives: 2007 4 Door Yaris
You could always drive through an icey cloud and sit out in a heavy frost.. ;)
Seriously though, if I was gonna spend more than 500 on a paint job, it better have a lifetime guarantee
Old 11-28-2009, 09:03 AM   #5
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Apparently you haven't been to a body shop in a long time. You can't get shit done for $500.
DerFlosser is offline   Reply With Quote
Old 11-28-2009, 09:45 AM   #6
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
no kidding, i couldnt get my bumper painted, off the car, with no taping needed for less than 350
Old 11-27-2009, 10:27 PM   #7
Lazerdot
Lazerdot's Avatar
Vinyl is an option, but I'm willing to "commit" to help create the look I want to help me market Trulube.com. Vinyl is changable if I get it wrong though. I'll try to post my XBOX 360 Yaris to get some opinions from all you guys. So far nobody has held back...
Old 11-28-2009, 02:42 PM   #8
supmet
Maaco has the "presidential service" which is a step above the cheapest paint job for 250 dollars...
I'm pretty sure they would do a bumper for 30 or 40, you got bent over alex.
Old 11-28-2009, 04:21 PM   #9
DerFlosser
DerFlosser's Avatar
Drives: Yaris
What? It just isn't possible to paint a car for that kind of money. I have never see a maaco paint job where the clear coat did not peel off within 1 year. You can't walk into a body shop and get anything done for $500 and the more overhead...the more expensive. It cost me $10,000 to paint my M3 and that was an "under the table" cash job. Granted it's a show car paint job but there is not one minor collision and or minor work that isn't going to cost atleast $500 or north.
Maaco.....god! Don't send the guy there!
Old 12-03-2009, 03:43 PM   #10
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
The Maaco paint is fine for a DD, but you'll get a better job if you do as much prep work yourself as possible. Despite all the comments to the contrary, I have seen a number of good paint jobs that lasted well from Maaco for under $1000. I've also seen a few crappy jobs, but they were the $199 cheap-o on a crappy car,a nd they didnt want to pay for proper prep.
As for the idea that you can get a bumper done for $30-40, that's not close. The cheapest you can get in for is about $150, no matter the size of the job. That's what the booth time and equipment set-up/cleaning justifies charging, even if its only a spoiler. The amount of paint and the size of the vehicle is almost irrelevant. that's why a same-color respray can be done so cheap if you avoid door jambs, hoods and trunks. those require quite a bit more labor than just sanding and spraying large, flat surfaces.
If you do go the Maaco (or similar) budget route, opt for the upgraded packages, or even spring for the 2-stage. Its worth it.
Also, ask around: different shops have vastly different reputations. I have a Maaco in south Dallas that is known to have a really good product because the shop foreman runs a tight ship. I also know of another in town that screws up jobs all the time and has to re-paint frequently. The good shops will have a reputation.
Old 11-28-2009, 03:25 PM   #11
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
do you have a concept pic?
Old 11-28-2009, 08:08 PM   #12
advocate
Drives: car
I saw a cheap ad for a Maaco paint job too. Sounded temping but you do get what you pay for...
Old 11-28-2009, 10:18 PM   #13
enviri
enviri's Avatar
Drives: 2010 Yaris
i got my rear RS rear bumper done for 420. its quality. alot of sanding and fixing was needed too, but..yeah...it looked great in the end. i would be prepared to spend somewhere north of 1500. its not a full repaint..looks like it could be like..a glitter clearcoat :P (i dunno lol)
Old 11-28-2009, 10:54 PM   #14
supmet
lol.. well maaco has an ad up for doing it for 250, so I guess its possible. Paint is like 50-500 bucks a gallon.. the yaris will probably take 2 gallons, if that, and unless you're doing a show job its less than a day of labor. 1500 max, 500 for medium grade paint, 250 for cheap stuff.
I can't imagine a bumper taking more than a quart, but even if it took 2, you can get that for 160(at consumer prices), and there's no way it should take longer than an hour to do a bumper. Or - buy a compressor, paint gun, paint, and enough plastic sheeting to cover your garage for 350 bucks, and have a compressor and paint gun left over..
You guys act like 3000 dollars of the 11,500 invoice went towards paint.. Your factory paint probably cost toyota 150 dollars, and would cost any body shop 3-400 dollars to do.
but my original point was, if I was going to spend 1/6th or 1/3 the price of the car on paint, it better have a lifetime guarantee.
Old 11-28-2009, 11:02 PM   #15
advocate
Drives: car
Good info.
I would agree.
P.S. I like the Dinosaris
Old 11-29-2009, 08:39 AM   #16
DerFlosser
DerFlosser's Avatar
Drives: Yaris
You've got it all wrong. The paint is the least expensive of all components. The paint is CHEAP. It's the correct prep that takes all of the time and costs all of the money. Anybody can buy an air compressor and some paint! Give these guys some credit....there is an art and science to good bodywork/paintwork. You make it sounds like any old Joe can do it. For example.....my father's 63 SWC had a full paintjob that cost $30,000. The amt of time spent on the car was unbelievable and that doesn't just include pre-paint....it accounts for all of the sanding and buff time after the paint is laid down. Very, very time intensive and there is a LONG line of people willing to plop down the money to have this guy paint their car. The paint is just jaw-dropping. As usual, in this arena, you get what you pay for and the numbers you came up with to properly paint a yaris are just ridiculous.
Old 11-29-2009, 02:15 AM   #17
lazerdot, do a full vinyl wrap, then you can get your effect and promote your business.
Old 11-29-2009, 04:01 AM   #18
YarisSedan
Drives: 08 Yaris Sedan
My mom got her van painted at macco about 10 years ago. The paint actually looks really good still. And she never waxes the car and only washes it once and awile. I think the key to her good paint job was the fact that she always washed her car with dish soap. So when it got there the paint was completed stripped of wax and residue. Which resulted in good ahesion with the paint. And possibly had a good bodyman that did good job prepping.
So just all depends on which one you go to. But i swear 10 years later in the sun with maybe 2 car washes a year and never had wax the car still looks really good.
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
The First Annual Kevin Duckworth Scholarship Car Show kingpincaraudio Northwest 5 06-24-2009 01:32 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
