Old 12-29-2009, 12:42 PM   #1
chew246214
Drives: 2009 yaris sedan base
sedan and wind.....
Ok sounds really dumb but I love the little sedan.. not a speed demon but great on gas... But myself and my wife both hate the fact that any little bit of wind and the car is thrown all over the place.... Any ideas what to do to help with this??? We live on the coast of RI and it seems to always be windy here so it's a big problem... Been debating about springs sway bars things like that but don't want to toss a bunch of money and be wasting it on a commuter car if it's not going to help.... it's reall driving us nuts otherwise the car is great... Plus it might just give me an excuse to do some suspension mods.. then of course tire and rims to follow... you know the deal...
chew246214 is offline   Reply With Quote
Old 12-29-2009, 02:54 PM   #2
supmet
Drives: 2007 4 Door Yaris
The sway bar is definitely not a waste of money. It helps a ton with the wind, and handling in general. I have a TRD sway bar, but garm sells pretty much the same thing, just a different brand here:
http://shop.microimageonline.com/pro...0&categoryId=4
Springs/struts and tires will help too reducing body roll and giving more traction, but the sway bar is by far the cheapest easiest fix for wind.
Old 12-29-2009, 02:58 PM   #3
JBIZZ
Drives: 2007 Liftback white
+1 on the rear sway bar. Lowering it will also help & the ride won't be as bouncy. The rear sway bar can be installed by anyone who can turn a wrench. Lowering springs can be installed by anyone w/ basic mechanical skills. I would suggest getting the Tokico blue shocks or TRD if you lower it, especially if you lower it below 1.5".
JBIZZ is offline   Reply With Quote
Old 12-29-2009, 03:57 PM   #4
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
all the suspension parts in the world WILL NOT help you with this car when the wind is
40-50 mph like today was. i got EVERYTHING possible under my car and it was a bitch trying to keep her on the road......
Old 12-29-2009, 05:46 PM   #5
YAR1S
YAR1S's Avatar
LBs feel the wind much worse I think.
Get yourself a Rear sway bar, collectively it seems to cut down on the wind thrown feeling.... I have yet to get one of these..... :p
-Jen <3
Old 12-29-2009, 06:59 PM   #6
chew246214
today I can understand, there is at least50-60 mph winds going and boy are they cold.... It's the everyday normal wind that concerns me... I deal with it, but my wife bitches about it so bad she dosen't want to drive it and wants to take the suburban which defeats the purpose of buying a car that gets 40 plus miles per gallon on a 75 mile commute to work....Just trying not to spend money on useless parts thats all..... Also found this ad...
*****For SALE w/ InstaLL Tanabe DF210 Lowering springs for 07-08 Toyota Yaris...used for the summer and now clean and in the box
---INSTALLED $250 within 2hrs
***Springs alone for $150 obo***
I need to double check it was for a sedan if not are they interchangable? and it seems like a decent price to me considering he is willing to install them.(I don't ave time) any thoughts?
Old 12-29-2009, 07:03 PM   #7
Springs are interchangeable between LB and sedan.
Might want to keep in mind that Tanabe DFs are a nearly 2 inch drop.
Old 12-29-2009, 07:08 PM   #8
chew246214
wow that was a quick response, Yea just saw that... since I don't plan on getting rims/tires just yet and this is a commuter plus it only has 1500 miles on it this might be a little too extreme to go with now....I'm thinking the sway bar would be a starting point..I do have the skills and usage of a shop for more advanced stuff but right now I'm gonna try to keep that on the back burner.....(lets see how long that lasts...)
Old 12-29-2009, 07:14 PM   #9
chew246214
Any other suggestions for a rear (anti) swaybar for the rear as far as bang for your buck.... supmet suggested the ultra racing, and I also found the TRD for $149.. any others cheaper? Better?
Old 12-29-2009, 07:40 PM   #10
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Wider tires are more prone to wander.
Old 12-29-2009, 08:50 PM   #11
chew246214
stock 15's no wander just pushing around from wind especially sidewinds.... actually not completly stock I have scion hubcaps for my snowtires that are stock size) I know how a wider tire will wander especially when braking hard I am more used to driving lifted trucks, this is only my 3 rd import car the others was a 4 door civic sport and I has a subaru legacy.... they both had rims/tires/ but no real bad effects from the combos except on the subaru I went too big of a rim and too low of a tire and kept destroying them on rough roads... which is why I do not want to go bigger then 16's on this car but trying to stay on 15's if I can..... this car is a commuter that is now getting driven daily in the last few weeks except the few days of snow....
Old 12-29-2009, 09:10 PM   #12
supmet
I agree in wet or bumpy roads, but just talking wind on the freeway, is wider really worse? I could kind of see spreading the weight out leaving you less planted, but it still doesn't make sense to me
@rockland
We've had pretty heavy winds out of the cajon pass the past few weeks with steady winds at 30-40 and gusts at 60-70. My sedan doesn't handle that bad, its a little scary sometimes, but I can definitely hold it steady. Maybe its time for an alignment
Old 12-30-2009, 07:52 AM   #13
ROCKLAND TOYOTA
TRIM HUNTER
NORMAL everyday driving will benefit from the swaybar right away and with the springs its makes things even better........
Originally Posted by supmet View Post
@rockland
not a bad suggestion seeing as its been almost 3 years now and it couldn't hurt. also the liftback isn't as wind friendly as the sedan so my normal commute yesterday was greeted by 2 hands on the wheel and the hopes there was no ice patches around when i got jolted.
Old 12-30-2009, 01:31 PM   #14
chew246214
BTW meant to tell you rockland toyota.... I used to live up by you and worked for the dodge dealer on 17 in Ramsey that closed... Used to drive by you all the time dealing with accounts and one of your techs or service guys used to buy parts from us all the time.... Find that kinda funny....
Old 12-29-2009, 09:46 PM   #15
That $149 for the TRD did not include shipping.
The Ultra Racing 19mm is $139 shipped (thanks supmet).
The 23mm version is $164.95. If you don't mind the extra $30, get that one.
Old 12-29-2009, 09:56 PM   #16
chew246214
Yea I can hold it steady, my wife complains about it she can also... It might just be an excuse to drive the suburban which she perfers... trying to stop the spoiled goody girl in her a bit and be practical
Old 12-29-2009, 09:57 PM   #17
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Lowering the car, low profile tires and rear swaybar are a must! I love the way it drives now.
CLA 250, 4MATIC
Old 12-29-2009, 10:41 PM   #18
chew246214
micro.. I know you are one of the fellow guru's here.. I did mention this to you awhile ago when you were testing a new set of springs a while back... would the 23 mm bar be too much for a daily driven commuter and not really driven hard at all... (not slow but not really tossed around though) It is staying basicly stock for now and I know too big an anti swaybar can also be a bad thing... I don't want unpredictible things happening.. we do drive this car 150 miles 5 days a week as of 2 weeks ago....this is another reason I'm debating if the car can also justify new springs and the price since it will be driven a lot and nowhere near a toy, it's a driver.... we have 10 days of commuting on it and about 1600 miles as of yesterday.... minus 3 days for the almost 3 feet of snow so we are definatly going to be racking up the miles.....
sedan handling sucks punch Performance Modifications 16 09-29-2006 09:26 AM
