Old 11-05-2006, 09:13 PM   #1
Driver
Driver's Avatar
Drives: 07 Yaris silver manual sedan
Thumbs down Using Cruise control
This is the first car I've ever had with cruise control so maybe I'm doing something wrong. It says when you reach the desired speed press the switch and Cruise will appear on the dash. OK, I reach 55 and press the switch and Cruise appears. I take my foot off the gas and the car starts to slow down. I push the cruise control lever up as suggested to increase the speed but it still continues to slow. What gives, should I take it to Toyota service?
Driver
Time is an excellent teacher, unfortunately it kills all it's students
Driver is offline   Reply With Quote
Old 11-05-2006, 09:18 PM   #2
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
yes
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 11-05-2006, 09:40 PM   #3
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
push the button to turn it on then you got to push it down to set speed
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 11-05-2006, 09:46 PM   #4
YamilR
YamilR's Avatar
You have 3 buttons. To turn on the control you push the one on the far left and youll see a green light come on. After that when you reach the speed that you want press the top one. If you press the brake the cruise control will deactivate, to activate it again press the bottom button. Also when the control is active you can press the top button to reduce speed or the bottom one to increase speed
Old 11-05-2006, 10:25 PM   #5
Driver
Driver's Avatar
Aha, I never pushed the lever down to set the speed. Thanks Gonzo I thought I was missing something.
Driver
Old 11-06-2006, 07:56 AM   #6
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
thats it. any questions you should prob check the manual before looking like an ass at the dealer
will work for parts
vodkalush is offline   Reply With Quote
Old 11-08-2006, 08:41 PM   #7
Driver
Driver's Avatar
Used the cruise control today and after pushing the button to turn it on and then setting the speed by pushing the lever down it worked like a charm. Now I'm ready for some long haulin'.
Driver
Old 11-05-2006, 09:47 PM   #8
YamilR
YamilR's Avatar
Dont push the lever or you will rip the cruise control out just press the buttons
Old 11-08-2006, 09:03 PM   #9
ceres
Club Baby Seals
ceres's Avatar
Drives: Yaris Sedan
um.... I don't have buttons on mine except the one to turn it on. You press the lever down or up to set it, slow down, and speed up. Just like you press the levers to turn on the wipers or lights. But I have a sedan (I thought the hatch didn't come with cc??)
ceres is offline   Reply With Quote
Old 11-09-2006, 12:02 AM   #10
Driver
Driver's Avatar
I have a sedan also. To engage the cruise control you first push the button in and when you reach your desired speed you then push the lever down. Once the control has taken over then you can use the lever to adjust the speed. Up to increase the speed and down to decrease it. See pages 122 to 124 of your owners manual.
Driver
Old 11-09-2006, 05:59 PM   #11
YamilR
YamilR's Avatar
"um.... I don't have buttons on mine except the one to turn it on. You press the lever down or up to set it, slow down, and speed up. Just like you press the levers to turn on the wipers or lights. But I have a sedan (I thought the hatch didn't come with cc??)"
Are you sure you have a cruise control?
Do you see the On/Off button, Then on top you have the Set/Coast and at the bottom the Resume/Accelerate? As you can see the cruise control is at a fix position, only 3 buttons to get the job done
The other lever on top is for the lights. Do as I explained on a previous post and you'll be good to go. Cruise control is aftermarket, but this is the one that you could get thru the dealer (Rostra)
Old 11-06-2006, 05:54 AM   #12
gonzo452001
my yaris doesn't have cruise but that's the way my taco's are
oem style foglights
Scan GaugeII
Old 11-09-2006, 04:00 PM   #13
regulus
Drives: yaris sedan
You have to push the button to get cruise control on and then push the lever down to engage it. After the first time pushing it down,pushing it again slows your speed. If you want to cancel cruise pull the lever towards you or push the cruise control button. It took me some time to figure it out.
regulus is offline   Reply With Quote
Old 11-09-2006, 07:25 PM   #14
ceres
Club Baby Seals
ceres's Avatar
Drives: Yaris Sedan
Yes I know I have cruise control. I use it a few times a week.
As you said, you have an aftermarket. Most people won't have your cruise control. Plus, the CC is on the right side for the sedan.
I couldn't find a close up pic of it but check out the top left corner V
Old 11-09-2006, 10:12 PM   #15
BMGYaris
Drives: Yaris 3dr Hatchback
"do you have cruise control..."
that was pretty insulting...do you know how to "quote?"
BMGYaris is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
Liftback - Easiest Way to Get a Tach and Cruise Control... weeze-dog General Yaris / Vitz Discussion 60 10-20-2006 05:40 PM
Rostra cruise control Yaris Dick Performance Modifications 14 10-09-2006 05:41 PM
