Old 01-23-2010, 03:45 PM   #1
wombatyaris
Drives: yaris
decrease in mileage
I have a 2007 4 door Yaris. I always got 40-42 MPG. Mileage has dropped to 35-36 MPG in the last few months. Tires are properly inflated, oil is changed regularly, air filter and plugs were recently changed with no improvement.
Any suggestions? Thanks.
wombatyaris is offline   Reply With Quote
Old 01-23-2010, 04:59 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Aside from the usual observations about winter gas, running the defroster which turns on the air conditioning compressor and so forth, consider checking your wheel alignment. A slight bit of tire scrubbing really eats gas. Also, an oxygen sensor that's gradually going out can cause a drop in mileage before it gets bad enough to trigger a "Check Engine" light. A 2007 is pretty new for that.
Old 01-23-2010, 10:44 PM   #3
MadMax
MadMax's Avatar
C'mon in and join the discussion!
Winter Gas Causing Drop in MPG?
Cheers! M2
Old 01-23-2010, 11:08 PM   #4
wombatyaris
Drives: yaris
The decline in mileage began before the weather changed and I've been through 2 previous winters. My driving habits have been pretty consistent. Will look into the alignment. Thanks.
Old 01-24-2010, 08:05 AM   #5
mark schofield
Drives: 03 Echo, 04 Scion xA, 02 Range
Have you tried cleaning the MAF sensor located on the air intake tube coming off the filter box? I remove mine and blow it off with an electronic parts cleaner spray every time I change the oil. There's a DYI here or on the Scion Life forum. They are quite delicate inside.
mark schofield is offline   Reply With Quote
Old 01-24-2010, 04:39 PM   #6
b_hickman11
Drives: 08 Sedan
Winter weather and winter gas are 2 different things.
Old 01-24-2010, 07:16 PM   #7
Conor
Drives: yaris 1.0 petrol (Y2K model)
Not in Ireland they're not :)
Conor is offline   Reply With Quote
Old 01-25-2010, 02:04 PM   #8
b_hickman11
Drives: 08 Sedan
He doesn't live in Ireland so why the hell would that be important to him?
So the Ireland fuel companies don't have a different formula during the winter and summer?
Old 01-25-2010, 04:20 PM   #9
Conor
Nope, we get the same fuel in winter as in summer. 95 or 98 octane.
Old 01-24-2010, 07:15 PM   #10
Conor
Check your plugs & air filter. I've noticed a dramatic increase in economy since the service I performed the other day. Best 60 quid I ever spent on parts. I managed 55mpg through the city to my parents house on Friday.
I think US gallons are different though, do you guys understand liters / 100km? I can test that way if needed. That's what we use in Ireland, but the wife likes MPG as she is old school
Old 01-25-2010, 02:16 PM   #11
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
Check your brakes-you could have either a front caliper or rear shoe dragging a little.
UTVitz is offline   Reply With Quote
Old 01-25-2010, 09:47 PM   #12
knowmercy
knowmercy's Avatar
Drives: Blk 3door
I get kinda sick and tired hearing about people complain about poor gas mileage. There is stuff all over the internet about it so if you can't look that up I'm not sure there's much hope for you. Also, quit going over the things this guy already said he did... checking the same things over and over is useless.
knowmercy is offline   Reply With Quote
-Mileage Thread- -Log your mileage, year, model, color, any problems here... Kal-El DIY / Maintenance / Service 322 07-20-2016 11:07 AM
2009 Yaris Mileage wornways Fuel Economy Forum 3 07-29-2009 12:42 PM
Mileage Histogram twowheels Fuel Economy Forum 0 06-19-2009 08:18 PM
Sedan better gas mileage than LB? 5 month gas chart included flint_mica_manual General Yaris / Vitz Discussion 24 03-09-2009 09:24 AM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 01:32 AM
