Old 02-04-2010, 03:12 PM   #1
Yar15
Drives: none
Winter and Heater (A/C)
Hi,
has anybody noticed that when you have car with full load of passengers in winter, the heater doesnt blow warm air enough and the back windows get steam.
Or if you try first at the cabin, windshield is on steam.
(Hoping that summer will come soon)
Yar15 is offline   Reply With Quote
Old 02-04-2010, 04:03 PM   #2
YAR1S
YAR1S's Avatar
Just moisture in the car... cant wait for summer to dry out my poor little hatch </3
-Jen <3
Old 02-04-2010, 04:06 PM   #3
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
yea same here, i just have a 2 year old in the back car seat in my sedan she fogs up the damn windows in the back i yell at her and say stop breathing lol (jk im not harsh)
Aothachos is offline   Reply With Quote
Old 02-04-2010, 04:31 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
tell your passengers to stop breathing... hehe.. Yeah, I live in a very humid place, and having just one extra person in the car makes it difficult for me.
Old 02-05-2010, 12:07 AM   #5
Sidicas
Drives: 2010 Toyota Yaris Hatchback
Roll down the windows and let some of that fresh winter air in
That'll defog your windows real quick.
Sidicas is offline   Reply With Quote
Old 02-05-2010, 03:11 PM   #6
MUSKOKA800
MUSKOKA800's Avatar
With the heat turned up, switch on the AC. This will de-humidify your environment while still providing heated air. Once all is clear, switch off the AC.
Old 02-05-2010, 03:18 PM   #7
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
That's what the defroster does whenever it's turned on.
Old 03-01-2010, 07:59 AM   #8
yaris2010RS
yaris2010RS's Avatar
actually its not the same. the defroster only partly uses the ac feature. pressing the button will allow for 100% Ac compressor. also with the ac on it allows u to set the blow mode to face (which i find helps the back windows alot more)
Just me $0.02....or with the exchange only about $0.019
Old 02-26-2010, 07:53 PM   #9
Yaris#2
Yaris#2's Avatar
Drives: 2010 5dr hatchback manual
Are you using recycled air or letting the flow through mode with your defrosters on. I find mine steam up if I am set to recycle the interior air. I also like to have the driver window cracked open at least a quarter inch. Both help with reducing the fogging effect. Turning the AC also helps quickly, but then your fighting the heater.
Yaris#2 is offline   Reply With Quote
Old 03-01-2010, 07:35 AM   #10
MUSKOKA800
MUSKOKA800's Avatar
I never switch to recycled air. Always fresh for me. Frankly, I don't recall having ever turned the knob to recycle. I see no point in it.
Old 03-01-2010, 11:05 AM   #11
Yaris#2
Yaris#2's Avatar
I see you are in Canada so it probably isn't an issue for you. When it is really hot in the summer I switch to the recycle mode for AC as it gets colder faster that way. Otherwise, I too prefer fresh air... unless fresh air is too hot to breathe.
Old 03-01-2010, 01:22 PM   #12
2009BBPliftback
2009BBPliftback's Avatar
I switch to Recycled air when I start to smell something foul IE a skunk or a smelly car in front of me it seems to keep the smell outside the car.
2009BBPliftback is offline   Reply With Quote
Old 03-13-2010, 12:22 PM   #13
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
Doesn't the window fog up faster when you have it set to recycled air and defroster mode?
KrazyDawg is offline   Reply With Quote
Old 03-13-2010, 01:13 PM   #14
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
Yep it does, for best defrosting make sure you're sucking in fresh air.
In the winter I usually use recirculate for the first 5 minutes of driving, then switch to fresh air when the engine is a little warmer and the windows are just starting to fog up.
Technically recirculate (or blower fan turned off) should help the engine heat up quicker, because you're not pulling as much heat out of the coolant when you're heating up recirculated air, as opposed to much colder outside air, for example.
BuildCode is offline   Reply With Quote
Old 03-13-2010, 02:18 PM   #15
Yaris Hilton
Smile
I keep it turned off for the first little bit till the engine's starting to warm up. Doesn't feel great to get in a cold car and just blow the cold air around.
Old 03-17-2010, 09:10 AM   #16
IllusionX
Drives: 07 Yaris Sedan Aero
^^ there's that.
but the canadian yaris.. and i believe the cold weather packaged yaris also, have an electric heater to help the interior warm up faster.
Old 03-19-2010, 06:31 AM   #17
yaris2010RS
Originally Posted by IllusionX View Post
^^ there's that.
has anyone actually found evidence of this? lol. i've seen it around here but is it actually true? i find in my car, untill the little green COLD light (which i am not a great fan of) turns off i willl not get much of any heat
EDIT: and would we also not get a little bit of a toaster like smell. all electric heaters let off some sort of smell for the first little while
Old 03-20-2010, 10:47 AM   #18
BuildCode
BuildCode's Avatar
Not sure, I wondered the same thing after reading about the electric heater on YW.
Is the cold weather package different than the all weather package? I just looked at my window sticker, and my "all weather guard" package has: Larger window washer tank with low level warning indicator lamp, heavy-duty heater, heavy-duty starter and rear heater duct.
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
