Old 02-25-2010, 09:42 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Which would you recommend for a yaris sedan single 10 inch or 12 inch sub
So I am going to have a custom box built into the spare tire area. I have my option of a mephis audio shallow mount 10 or 12 both would fit he says. Both will cost me roughly 400 installed that includes the box wiring and sub im supplying my own amp.
Which do you think would sound better. for the size of the car and the air space in the trunk.
Old 02-25-2010, 09:54 PM   #2
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
if theyll both fit the same get the 12...quite simply so long as you can power it properly
PG TLD22 8V Line Driver
Old 02-25-2010, 10:03 PM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Which sedan you have the s model or base model, on the base models if you remove that cardboard backing you have More trunk hiding behind there.
Old 04-16-2010, 09:17 PM   #4
Malifabian
Malifabian's Avatar
Drives: Yaris Sedan 2008
12" if you like deeper longer sounding bass, and 10" if you listen more to short, fast sound bass IMO. Im getting a 12" sub that is already in an enclosure. I can't wait till I install the amp for it. Ill let you know how it sounds.
Malifabian is offline   Reply With Quote
Old 04-26-2010, 09:41 PM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
thats an old audio myth... the size of the sub has nothing to do "fast" or "slow" bass. The motor (voice coil and magnet) are what determines that... also the configuration of the box has a big (VERY BIG) effect on the so called speed of the sound.
the best I can do to explain this without getting long winded and technical is to say that the 12" for deep, and a 10" for fast is like saying small cars are slow and big cars are fast. No.. it determines on the engine, high HP & decent torque is what will determine if a car is fast... that along with the relative power to weight ratio.
I wish I had everybody here, a few hours with a saw, and an 8" & 15" sub... i'd make boxes that make the 8" sound boomy/slow and the 15" tight/fast.
Old 04-27-2010, 12:46 PM   #6
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Offtopic
I like ur avatar pic I wonder whos car is it?
Originally Posted by sw07gt
Old 04-17-2010, 04:46 AM   #7
typicaljawaiian808
Drives: '09 Yaris Sedan
Pioneer
Ascendant Audio
Sundown Audio
DC Power Engineering
Knukoncepts
Fosgate
Stinger
typicaljawaiian808 is offline   Reply With Quote
Old 04-17-2010, 07:24 AM   #8
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Wow...what a waste of space! Holy crap! How many cubes is that?
...that sounds trollish, but it REALLY isn't. I promise.
― Thomas Paine
Old 04-17-2010, 01:09 PM   #9
_S7V7N_
_S7V7N_'s Avatar
I'd like to hear what that sounds like... And i'm betting around 3.5-4 cu ft of airspace. Deff enough to cut a square hole in the front of it and slap a Solo-baric 15 in there and knock the trunk off it's hinges.
Old 04-17-2010, 05:28 PM   #10
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
Looks to me like he has TWO of those subs in that box.
( from looking at both pics )
And the box is ported. Those look like 12's ?
Since those subs are on opposite walls, are they wired for PUSH-PULL?
( or do you have internal walls between them? )
Interesting setup.
I think I would pass on the window decals though... don't like advertising to thieves.
Old 04-17-2010, 07:23 PM   #11
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Originally Posted by Alien Mantis View Post
Interesting setup.
I never thought about that! very clever.
D.
CLA 250, 4MATIC
Old 04-17-2010, 09:08 PM   #12
sqcomp
Roadrunner Jr.
sqcomp's Avatar
You could put 4 solobaric 15"s in 4 sealed cubes! Can you imagine that?
― Thomas Paine
Old 04-18-2010, 09:36 PM   #13
derickveliz2
That would be awesome!!!
D.
CLA 250, 4MATIC
Old 04-27-2010, 01:14 AM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Hey...Let ME take care of the fast 15s! I've got two waiting for the enclosures to be fabbed. We're doing a cube and a half sealed on each of the two ID 15s. Something tells me I'll have an excellent sound from them.
― Thomas Paine
Old 04-27-2010, 10:56 AM   #15
derickveliz2
You mention before that your boxes were going to be vented? is that the plan? if so, is the volume inside the vents included in the area? I can't wait to see how you are going to layout your amps and woofers, I'm hitting my head on the wall thinking about it, in other words I don't know where I'm going to install my amps
CLA 250, 4MATIC
Old 04-27-2010, 11:41 AM   #16
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
i'd assume 1.5cuft each sealed.... you got 2-3bands of eq in the sub 60hz range?
Old 04-27-2010, 12:35 PM   #17
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I've got dual 1/3 octaves for the right and left off the source. No worries about control. Yes they will be sealed, I can completely sympathise with the banging of the head against the wall thought. We WERE contemplating the sealed idea, but I nixed that with the space requirements for the frequency range and placement we wanted of the woofers. We also changed amplifiers so I'll ONLY be working with 1000 Watts at maximum for two 15 inch woofers. Oh bummer.
― Thomas Paine
Old 04-27-2010, 12:46 PM   #18
derickveliz2
I wish, I think I'm in the 450 Watts for three 10 inch woofers. "We all want more, and MORE" Can't stop
D.
CLA 250, 4MATIC
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Yaris Sedan shown on Toyota Canada webpage GabL General Yaris / Vitz Discussion 14 03-10-2007 06:13 AM
