Old 03-09-2010, 04:56 AM   #1
Boomslang
Drives: 2007 Yaris T1
Post 1KR-FE 998cc Repair manual?
Hi
I'm in South Africa, and have the 2007 1KR-FE 998cc 3 cylider petrol engine in my Yaris. I can find almost every other engine variant's manual, but not for this one. I also phoned a Toyota dealer, and he said he can't help??
Any links or place where I can buy the repair/service manual for this engine please?
Thanks,
Darius
ps: Even just the torque specs for the head, main- and big-end-bearings will already help a lot.
Boomslang is offline   Reply With Quote
Old 03-10-2010, 12:37 AM   #2
Attached are the service spec docs that I have for the 1KR-FE
1KR-FE Engine Control System Service Data.pdf
1KR-FE Engine Control System Torque Specifications.pdf
1KR-FE Service Data.pdf
1KR-FE Torque Specifications.pdf
Old 09-04-2011, 06:03 AM   #3
zaindaman
Drives: toyota Passo
Attachment 32340
Attachment 32341
Attachment 32342
Attachment 32343
Hi Scott,
can you email me the repair manual for 1kr-fe engine and A4b-D transmission. to my email, zain.rizvi20@gmail.com, Thank You!
zaindaman is offline   Reply With Quote
Old 09-04-2011, 10:11 AM   #4
Originally Posted by zaindaman View Post
Hi Scott,
I am not aware of any transmission called the A4b-D. Do you mean the K41 CVT?
Old 03-15-2015, 03:32 PM   #5
LESTER TEMMERS
LesCTN
Drives: 1KR FE Toyota Yaris 2007
Send a message via AIM to LESTER TEMMERS
Hi Scott, will you be able to send me the Yaris Repair Manual for my vehicle type. 1KR-FE please.
LESTER TEMMERS is offline   Reply With Quote
Old 05-05-2015, 09:31 PM   #6
Ventoy
Drives: Vios 09
Attachment 32340
Attachment 32341
Attachment 32342
Attachment 32343
I ALSO NEED REPAIR MANUAL KINDLY MAIL ME
rcortidor@yahoo.com
Ventoy is offline   Reply With Quote
Old 09-18-2016, 07:14 AM   #7
samuely55
Drives: toyota, passo/ vitz
My car is a 2004 toyota passo, engine type is 1KRFE, AUTO GEARBOX. Thanks for the links, I found them useful. I have a problem with the automatic gearbox. It lacks power on uphill. Beforehand, it used to jerk when gear is selected. So I am assuming it all has to do with the gearbox.
I would appreciate if anyone can share his knowledge on how to check gearbox oil level. Should I run the engine for a while and look at the reading? Or I can just have a look at the reading when engine is cold?
Thanks
samuely55 is offline   Reply With Quote
Old 03-10-2010, 03:47 AM   #8
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Drives: 2006 3d 1.0 Linea Sol
Thanks!
The blue one
Old 03-10-2010, 05:08 AM   #9
Boomslang
Thanks!!! At least the torque specs will help.
I thought the head bolts will be stretch bolts that you fasten to say 30nm and then 90degreeX2 turns? Does anyone know if that's the case?
Thanks again!!!
Old 11-12-2010, 11:59 AM   #10
danoeac
danoeac
Drives: toyota yaris 2006
Hi all, I'm new. I own a Vitz 2006. Engine making a strange noise. Looks like its coming from a noisy belt pully. I'd like to fix this myself. Looking for a Repair manual 1kr-fe engine with a K410 transmission (CVT) JDM. Can anyone help me ?
danoeac is offline   Reply With Quote
Old 11-15-2010, 02:51 AM   #11
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
I wish,
I got my car running recently after a motor cange, I cant find a maunal anywhere!!!
So if anyone is out ther, please!
We need the manual, the Repair manul, the ECU manuals....
Regards
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
Old 05-29-2011, 10:39 AM   #12
topten2004
Hi CTScott, would be great if you can mail the 1KR-FE manual to me:ct.tsinghua@gmail.com Thanks a lot!
topten2004 is offline   Reply With Quote
Old 11-15-2010, 11:25 AM   #13
I have the complete engine repair manual for the 1KR-FE, but it's too large to post. If you PM me your email, I can email it to you in sections, as the whole thing is about 40MB.
Old 12-03-2010, 12:40 PM   #14
anuradha herath
Drives: Yaris & Passo
Hi CTScott,
Please mail the repair manual for the 1KR-FE to me too..........
E-mail: na.herath@gmail.com
Thanks.
anuradha herath is offline   Reply With Quote
Old 12-06-2010, 01:03 PM   #15
danoeac
danoeac
Hi CTScott, how can we share the cvt manual ? Possible to scan and post at least the K41A manual ? Let me know.
Old 12-06-2010, 04:30 PM   #16
I just emailed you the info for the K41A manual.
Old 03-17-2012, 11:20 AM   #17
Lourens Diedericks
Drives: Toyota Vitz 1.0 2005 1KR-FE
Toyota Vitz 1.0 2005 Automatic
Good Day All,
I own a Toyota Vitz 1.0 2005 1KR-FE XP90. I am looking for more technical information such as; spark plugs and oil filter parts descriptions. I had an oil change done by a mechanic but he refused to tell me the make or part number of the parts he used, basically making me wonder if he ever did anything . . I found NGK spark plugs, part nr. BKR5EYA, stock nr. 2087, is this the right plug to use for my car? Also, i found out the oil filter must be the cartridge type, right? Any information on this or at least a confirmation that i am on the right track will be greatly appreciated.
Thank You,
Lourens
Lourens Diedericks is offline   Reply With Quote
Old 06-07-2011, 06:14 AM   #18
Buddhikka123
Drives: Toyota VITZ
Hi CTScott,
Can you please mail me the repair manual for the 1KR-FE.
E-mail: buddhishani@hotmail.com
Buddhikka123 is offline   Reply With Quote
Looking for fender liner repair manual. eii DIY / Maintenance / Service 1 06-07-2009 07:48 PM
C54 MANUAL TRANSAXLE service manual needed ricepower DIY / Maintenance / Service 1 08-29-2007 08:24 AM
The Toyota Authorized Repair Manual. LoudYar General Yaris / Vitz Discussion 3 03-29-2007 01:20 AM
Price for paper version of repair manual? Snappy DIY / Maintenance / Service 12 12-18-2006 07:45 AM
where online to buy a shop repair manual? punch DIY / Maintenance / Service 31 09-12-2006 03:50 PM
