![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
tpms
I've looked and tried to find the answer before asking:
Is there a DIY way to have the car's ECU re-learn a new set of TPMS without having to go somewhere and have it done?
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
I only remember seeing a DYI disable for them.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
The TPWS can only learn new sensors with the use of a service tool. Most tire shops (and of course dealers can do it).
Do you happen to know what the service tool is? My fiance has a crap load of tools from when he used to work as a mechanic, so it's possible he has it already. That's the main reason I asked.
Not a mechanical tool, but an electronic one - Either the Toyota TechStream tool or a TPMS diagnostic tool.
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback Join Date: Jan 2010
ok honest question here.... does it matter if you dont use your sensors at all on aftermarket wheels?
![]() Drives: '08 Yaris LB 5M Join Date: Nov 2008
Does it matter? To a Federal Bureaucrat it matters. To me, ..... I just disabled the TPMS and have no sensors at all in my aftermarket summer wheels. My winter wheels still have them but they are just useless rotating mass now.
Half a Bubble Off Plumb
If it doesn't bother you to have that low tire pressure warning light constantly lit, and you'll keep your tire pressure checked regularly, it's no biggie.
![]() Drives: 09 Flint Mica Sedan Join Date: Feb 2010
how did you disable your TPMS? I'm looking for a solution to end once and for all the constant tire pressure light. I didnt get the sensors installed on my after market rims..and don't want to deal with the light anymore
#10 | |
Jump right to post #115 |
#11 | |
i read your original post then the pg 3 info w/ all the parts from radio shack...post 115 just looks like the brown wire was cut and tied to the white wire #6. is this correct? and if so, what did you use to connect the brown and white wires? |
#12 | |
You are correct with simply cutting the brown and connecting it to the white. You can use a simple tap splice connector to do it (available from any autoparts store). |
Chunk love Yarii
well then i dont really care....... i take good care of my vehicle
#14 |
I don't like having the TPMS as it is. But wouldn't it be cool if it would give you a readout of the actual pressure in each tire?
#15 |
It would - They report pressure and temperature, so it would be very cool to have a live display of both for each tire. One of these days I'll figure out the protocol for the Yaris TPWS and make a device to do so. Crashy will be my test platform, since she has my 09 steelies with the sensors. Both of my sets of alloys that I run on my 09 are sensor free.
#16 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
-Steve |
#17 | |
#18 |
I love momentum.
So far as I know, every time you change wheels (if going between winter/summer), you have to pay to have the TPMS re-calibrated. And because of that I simply disabled mine. I check my tires pressures regularly, I don't need a (generally useless) electronic babysitter.
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 02:00 PM |
| tpms compatibility? | bwong2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-11-2009 09:33 AM |
| TPMS Gauges - do they exist? | Sodium Duck | DIY / Maintenance / Service | 24 | 03-01-2009 12:18 AM |
| 15" TPMS friendly wheels for my '08. Ideas? | auxmike | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 12-08-2008 08:01 PM |
| TPMS | TinyGiant | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-22-2008 03:57 PM |
