Old 04-07-2010, 02:14 PM   #1
Emerge
On a trek to upgrade...
Drives: 2003 Echo Coupe
Anyone work on a 03 Echo?
Trying to get into this whole modding thing to no avail thus far. I have been told I need to replace my struts, and I figured I could go ahead and get a decent suspension and lower my ride a bit while I'm at it.
The problem is, I know nothing about cars and all the information on this forum is specifically about the Yaris. Also, most google searches yielded weak results.
Emerge is offline   Reply With Quote
Old 04-08-2010, 03:38 AM   #2
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
www.yarisclub.gr
tein basic coilover
yaris 2sz is offline   Reply With Quote
Old 04-09-2010, 12:52 PM   #3
Emerge
Thanks so much! I appreciate the help.
However, the URL you gave me is a bit hard to follow.
Old 04-09-2010, 12:54 PM   #4
Emerge
http://www.tein.com/products/basic.html
Is this what I'm looking for? Are new struts included in this package?
Old 04-10-2010, 02:36 AM   #5
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
yes. struts and springs.
the tein basic is perfect for the first yaris (echo).
Old 04-10-2010, 09:08 PM   #6
Emerge
Thanks bro, I appreciate it very much!
I've also gotten a bit of a breakthrough after weeks of looking! NST told me that their pulleys for the Echo are the same ones that fit the Scion xA/xB. I figured out that they might have more in common. So, I came across this thread:
http://www.toyotanation.com/forum/sh....php?p=2243026
It's too bad that echodrivers forum link is a 404. :(
Now I have to find out what a normal strut replacement would be if I wasn't going for aftermarket stuff so I can do the price comparison.
How much would you suppose this would lower my ride?
Old 04-10-2010, 10:08 PM   #7
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Echodrivers
What were you looking for there? Echodrivers is my home turf.
Edit: oh, ok I see what link you're talking about now... Fixed it. A while back the forum was updated and the "s" was taken off of "forums". Most links are still broken.
Old 04-10-2010, 10:50 PM   #8
Emerge
Ah!
Thanks man, that's a good look. :) It has been really tough to find options for my little ride. Right now it's pretty pathetic, but it's going to be awesome when I'm done with it.
Old 04-11-2010, 12:15 AM   #9
frbl
Drives: 2005 Scion xA
Try Scionlife.com - the Scion xA and xB (1st generation) have a great deal in common with the Echo, especially mechanically. This site even has specific info in the Tech section for the Echo, but much of the other stuff should also apply. The DIY for changing struts should prove helpful to you.
frbl is offline   Reply With Quote
Old 04-11-2010, 03:35 AM   #10
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
toyota prefer kyb.
so 333258 for front, 343295 for back axle
http://www.kyb.com/pdf/kyb_catalog.pdf page 143
Old 04-11-2010, 07:12 AM   #11
mark schofield
Drives: 03 Echo, 04 Scion xA, 02 Range
http://www.echodrivers.com/
mark schofield is offline   Reply With Quote
Old 04-11-2010, 07:34 AM   #12
echodrivers is a good resource, but only if you can get the admin to turn your account on
go to scionlife....xa and xb1 use mostly the same parts for intake, header, exhaust, suspension, brakes, wheels/tires
Old 04-11-2010, 07:59 PM   #13
Emerge
A lot of good information fellas, appreciate it.
Old 04-11-2010, 08:30 PM   #14
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Although our steering wheels are on the other side, www.ozecho.com might also have some info for you.
rob323 is offline   Reply With Quote
Old 04-14-2010, 02:26 PM   #15
Emerge
Guys, I would like to buy new wheels and tires. From what I have read on this forum, I should first install the shocks+struts before I buy new wheels?
Old 04-14-2010, 04:09 PM   #16
rob323
Nope, do it in what ever order you like. You will need to get a front wheel alignment after you install the front struts though.
Old 04-14-2010, 10:30 PM   #17
Emerge
I read in another thread that when a car is lowered, the wheel and tire options change because of the drop.
Old 04-14-2010, 10:40 PM   #18
rob323
Ok, I see where you are coming from. If you are getting wider wheels than yes, you have to be careful how much you lower the car.
echo
Toyota Echo and Yaris TWM Short Shifter Sale! TWM Performance TWM Performance 3 08-24-2009 10:50 AM
LF: Yaris / Vitz / Echo hatch accessories / parts! Keej_05RS General Yaris / Vitz Discussion 3 12-08-2008 09:43 PM
Will this work? umm_bacon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-10-2007 09:16 AM
My Work, Your Work - Stories and Fun SmallCarGuy Off-topic / Other Cars / Everything else Discussions 0 09-02-2007 07:43 PM
Anyone in So Cal needs work on their Yaris Bdaslug California 24 08-26-2007 05:10 AM
