Old 04-21-2010, 09:38 PM   #1
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
RATTLE?!?!? From where?
Ok so this problem just started to happen and it is baffling my brain.
Just when cruising along I can hear a rattle, sort of like there is a screw or rock inside of the exhaust just getting jostled around.
It is coming from the right rear of the car and it is really driving me nuts. Or atleast sounds like the right rear of the car.
Anyone have any ideas?!!?
Old 04-21-2010, 11:25 PM   #2
swidd
Drives: Yaris HB
First check items in the cargo area, seat belts, center rear seat belt. This is often the case for me. My last rattle was a loose seat bolt, loose interior clips, cd covers, and a wire harness that vibrated.
Old 04-21-2010, 11:28 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
rattles are hard to trace down as the sound reflects off all the plastic and glass so easily.
the trick is to know if it is a metal, or plastic rattle.
I had an issue with my rear brake light indicator, but it could be anything... so i'm not even going to try and guess.
Old 04-21-2010, 11:31 PM   #4
Ryu
Check your spare tire area and the tool area on the right side of your spare tire to see if there is something there might hitting around while you are driving.
Old 04-21-2010, 11:39 PM   #5
swidd
Drives: Yaris HB
If it's the rear brake light assy, you can stuff a towel up against it through the covers in the rear, without removing any panels.
Old 04-21-2010, 11:54 PM   #6
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
my yaris has so many rattles, it pisses me off!
Old 04-21-2010, 11:59 PM   #7
Nexus1155
Drives: Audi
Thanks everyone I'll try to check some things out tomorrow
And I don't think I would mind a couple of rattles if I had a turbo/supercharger...
Old 04-22-2010, 12:32 AM   #8
swidd
Drives: Yaris HB
I found that almost every interior clip in the dash was rattling, or at least loose enough to rattle when tapped. So put scotch tape inside every one of them, and silence the dash....
Old 04-22-2010, 01:04 AM   #9
yaris2010RS
yaris2010RS's Avatar
i had a rachet extension fall into my spare tire area and it took me about a week and completly ripping my car apart to find out that was the niose. lol. it really sounded like it was coming from under/outside the car.
Old 04-22-2010, 11:58 AM   #10
Qilene15
I managed to drop an allen key inside the rear bumper of my sedan while putting the wires into my amp. Wasn't able to find it :P
Qilene15 is offline   Reply With Quote
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 12:29 AM
rattle bluebeast General Yaris / Vitz Discussion 1 04-12-2010 01:13 PM
Exhaust rattle? Cutie Pie #2 DIY / Maintenance / Service 3 11-14-2008 06:46 PM
Rattle fixed! Bretsuaz DIY / Maintenance / Service 32 03-30-2007 08:39 PM
