![]() Drives: yaris Join Date: Jan 2010
how do i remove my hubcaps
i am a car noob pls help me
how do i remove hubcaps from my '10 yaris thanks |
Grab them and give them a good yank.
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
Use something to pry it open from the side or you probably can pull them out just using your hand from the side.
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Why do you want to remove the hub caps?
Drives: yw calls me douche and racist. Join Date: Aug 2007
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
A thin screwdriver and work it around the wheel. Also if you have trouble getting them back on mix up some soapy water like dish soap and a gallon of water and pour it around wheel. Hub caps will go on much easier
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
Just grab them and pull out, make sure that your butt doesn't end on the floor like happened to me once!!!
| DIY : How to remove door panels | FEINT | DIY / Maintenance / Service | 13 | 11-18-2021 02:16 AM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| Steelies or Hubcaps or ??? | CtrlAltDefeat | Cosmetic Modifications (Exterior/Interior) | 50 | 10-24-2013 09:50 PM |
| [DIY] To remove logotipos of the mark | Sérgio Barros | DIY / Maintenance / Service | 6 | 02-23-2007 07:32 PM |
