Old 06-04-2010, 12:53 PM   #1
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Send a message via AIM to falkor_99
215/45/17 to 205/40/17
So I have a set of Falken 912s that are wearing down. These wheels were very good. Lasted a while, got at least 50K on em. There is still some tread left but at the rate im going, im gonna need some new tires soon. So im thinking about going to a smaller size cuz i rub a lil. So im thinking that if i get the smaller wheels that i wont rub AS MUCH.
Does anyone have any opinions of how the ride quality will be with that size tire?
Thanks
falkor_99 is offline   Reply With Quote
Old 06-04-2010, 05:09 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
more harsh.
if you're rubbing, fix the problem. add some camber, trim your fender liners, etc.
can you give your wheel specs please?
also remember, with the shorter tire you'll have more "wheel gap" and your speedo will read higher than you're traveling
Old 06-05-2010, 11:16 PM   #3
falkor_99
falkor_99's Avatar
Right now I have 215-45-17
I have already trimmed the fenders. I haven't added any camber yet though, I'm not sure what I would need to do for that.
Old 06-07-2010, 10:09 AM   #4
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
I added Camber to it and it fixed the problem with 215 but I think I want to go 205 and my car is slammed so it does it helps alot
Originally Posted by sw07gt
Old 06-07-2010, 10:09 AM   #5
JumpmanYaris
USAF_SrA_E-4
Camber bolts from Garm
Old 06-07-2010, 08:12 AM   #6
MUSKOKA800
MUSKOKA800's Avatar
From the pinned Wheel & Tire Guide.
FYI, OEM diameter is 23.7". Your 215/45/17 size is likely much too tall, hence the rubbing. Assuming the wheels are a correct spec., if I were you I'd switch to the 215/40/17 which would soon wear into OEM size range.
205/45/17 = 24.3*
205/40/17 = 23.5*
215/40/17 = 23.8
Good Luck!
17x7 +38 rims with 215/45/17 tires c-one yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 06-19-2012 02:59 AM
215/45/17 on stock suspention ,want to verify Arkhangel Wheels, Tires and Suspension Forum sponsored by The Tire Rack 36 08-10-2009 08:23 PM
anyone rubbing on 205/40/17 with trd when full?? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 04-14-2009 12:28 AM
205/45/17 or 205/40/17 Front & 215/40/17 Rear vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 09-21-2007 07:55 PM
Llantas 205/40/17 R()ger Central and South America 7 06-20-2007 01:57 PM
