Old 11-29-2006, 09:41 PM   #1
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
DIY - How to change you stock radio color
Change LCD/Radio Color
The Goal: Replace the stereo’s nasty 80’s green color with a bitch’n white (or whatever color you want - blue may cause your LCD text to display "dimmer")
Tools Needed:
- Hand’s
- butter knife
- 10mm socket
- soldering iron (with fine tip)
- solder
- small needle nose pliers/tweezers
- masking tape (or some sort of removable marker)
- 70 New LEDs (I went white for all but on each of the CD slot, which I went blue; also the closer count needed is around 64-68)
*** I ordered these White LEDS - http://www.eled.com/product.asp?cata...EPT2012RWF%2DA
*** I ordered these Blue LEDs - http://www.eled.com/product.asp?cata...=EP2012PBC%2DA
The Guide:
1. Remove bottom of center console (pull from side)
2. Remove “side skirts”; pull from bottom to the top
3. Remove gauge “shell,” pull out
4. Remove 4 screws holding in stereo (10mm socket)
5. Remove “warning/seatbelt” wiring; pinch and pull
6. Pull stereo out; pinch and pull all wires going into back of stereo (antenna not shown)
7. Bring the stereo inside to where ever you are going to work on it, make sure to choose a place free of static; or atleast be sure to ground yourself (I choose my coffee table; prob not the best place :-)) and start the disassembly. Use a butter knife to “pop” the 6 tabs (goes all around the stereo;4 in front: 2 in back)
(place stereo aside; as it’s the “board” the has the LCD and radio button LED’s)
8. Remove screws holding the board to the plastic front of the stereo
9. Remove the board from the plastic housing
10. Put a piece of masking tape at the top of the LCD, then flip the board over and straighten the “pegs” holding down the LCD to the board with pliers.
Remove the LCD housing, taking note to make sure you mark every piece at the top (sorry no pics), also remove stereo knobs (mark one of the knobs, they only fit one way)
11. Un-solder the LEDs (I did a combo of un-soldering the correct way, and simply heating up the whole LED and having it “break apart”) I would google “how to un-soldering
12. This next step is what took me the longest, but is really not that hard. Time to solder the new LEDs on. On the bottom of the LEDs I ordered (eled.com) there is an arrow, point that towards the opening of the half box (see pic) and solder the new one on, you may need to add a dab of solder on the new LED (as the connection point is at the top of the LED, not the bottom)
(I used small pliers to place the new LEDs)
13. Put everything back together the way you took apart, put there stereo back in the car.
edit: when you are putting the LCD "bracket" (last part of step 10) back on the make sure that you bend the "pegs" make enough to make a good connection with the board or else the LCD wont display right (to fix this if it happens all you have to do it open everything back up and simply bend the peg (the one near the "nonworking" section of the screen) in a little more.
I hope this helps those looking for a solution to the soylent green color of the stock stereo.
happy modding
(this was my 500th post )
will work for parts
vodkalush is offline   Reply With Quote
Old 11-30-2006, 12:28 AM   #2
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
This looks great! It's much the same thing that Celica owners have to do to change the color of their gauges... For those who aren't comfortable with soldering irons, for the love of god let someone else do it... I'm fairly sure Toyota wouldn't cover this one on warrantee.
paultyler_82 is offline   Reply With Quote
Old 11-30-2006, 12:39 AM   #3
H8SGAS
H8SGAS's Avatar
Drives: Black Liftback
Delicious, Delicious, Delicious, Delicious!!!!!!! I need a smiley with its jaw dropped like it has just seen the Nice Ass Thread!!!
Well if it’s not a hybrid how do you get such good mileage?
H8SGAS is offline   Reply With Quote
Old 11-30-2006, 01:48 AM   #4
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
lol
eco is offline   Reply With Quote
Old 11-30-2006, 06:26 AM   #5
vodkalush
I drive a yarrrris
vodkalush's Avatar
if you've never soldered in your life, buy a 12pack for a friend (after they've finished soldering )
but really, the only soldering I've done has been with wireing, they key for me was to take my time and not rush. Also I would recommend someplace a little better then a coffee table to do this
FYI - I'm taking the Gauge Cluster out tonight...
will work for parts
Old 11-30-2006, 11:25 AM   #6
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
very impresive! nicely done!!
Old 11-30-2006, 01:20 PM   #7
ChinoCharles
Drives: LB
If you figure out that gague cluster, not only will I be impressed, but I will owe you one mind-altering substance of your choice.
Hey, some people don't like alcohol. Haha.
Old 11-30-2006, 01:37 PM   #8
vodkalush
I drive a yarrrris
vodkalush's Avatar
I might just take you up on that
will work for parts
Old 11-30-2006, 08:11 PM   #9
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
that looks very hard
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 11-30-2006, 09:23 PM   #10
ChinoCharles
Drives: LB
Vodkalush, I would add a comment about static to that DIY. You had the board on a wood surface which is fine, but if you do this say on carpet you're liable to fry that board. No wool either.
Old 12-02-2006, 04:55 PM   #11
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Excellent!
Old 12-03-2006, 09:41 AM   #12
vodkalush
I drive a yarrrris
vodkalush's Avatar
edited post to include comment about static, as well as added the number of LEDs needed.
will work for parts
Old 12-05-2006, 02:14 AM   #13
ChinoCharles
Drives: LB
Vodkalush, how many LED's for just the climate controls? I have an aftermarket HU.
Old 12-05-2006, 06:29 AM   #14
vodkalush
I drive a yarrrris
vodkalush's Avatar
I used this guide a basic outline (shows how to remove climate control cluster) - http://www.yarisworld.com/forums/showthread.php?t=2150
and then ordered Neo Wedge Blubs from the site listed in this thread - http://www.yarisworld.com/forums/showthread.php?t=2150 specificaly page 6 post 85
Originally Posted by Violin View Post
For the gear shift I used the "Tri-Power 3 LED Bulb - The Widest, 3x Brightest and Best #74 Leds Ever Made!"
The ventilation controls are the "Neo - Wedge Instrument Panel Bulbs are 10mm (3/8") diameter x 13mm (1/2") high" at $2.99 each.
http://autolumination.com/74.htm
Polarity matters with LEDs. If you put one in and it won't light - take it out and rotate it 180 degrees.
hope this helps
will work for parts
Old 12-05-2006, 07:25 AM   #15
vodkalush
I drive a yarrrris
vodkalush's Avatar
edited first post to include LEDs that I purchased.
will work for parts
Old 12-05-2006, 11:07 AM   #16
ChinoCharles
Drives: LB
Thanks buddy.
Old 12-15-2006, 12:53 AM   #17
Bones
Bones's Avatar
Drives: 07 Yaris S Type
Here's a picture of all blue LEDs in the radio. In the picture the blue looks aqua, but it's a real deep good looking blue.
Thanks for all the help and info Vodka!
Bones is offline   Reply With Quote
Old 12-15-2006, 09:45 AM   #18
DorytheYaris
aka Eleni
DorytheYaris's Avatar
Drives: 10 Yaris LB Auto- Blazing Blue
I want blue LEDs :(
Being a girl sucks. I don't have the skills to dig into my dashboard! I'd wind up paying an arm and a leg to have someone do it for me. Gah!
DorytheYaris is offline   Reply With Quote
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 02:41 AM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Preview - Radio color change: step 2 vodkalush Cosmetic Modifications (Exterior/Interior) 10 11-30-2006 02:49 PM
My radio color change - step 1 (pics inside) vodkalush Cosmetic Modifications (Exterior/Interior) 16 11-22-2006 07:48 PM
Change the Console Control/Shifter Color Ayka Cosmetic Modifications (Exterior/Interior) 1 09-28-2006 11:21 AM
