![]() Drives: 09 grey Yaris hatch Join Date: Aug 2009
Jackhammer noise?
Probably about a week ago, a jackhammer noise started to appear on the left front drivers side of the car. At first, it was softer and has gradually gotten to very loud as of now. The tires, wheels, brakes, and hubs have all been checked. Has anyone had a similar problem or can diagnose it? My friend and I checked a few things out and have it narrowed down to either being axle or transmisson related.
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
Is it when braking?
Drives: yw calls me douche and racist. Join Date: Aug 2007
I think ur shock is blown.
It is at lower speeds and when I get off of the gas..
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Inboard CV joint?
Reason being I had a VW that failed within a year due to not enough grease in the inboard joint. Made lots of noise and caused vibration some times. Happened while driving on the freeway, in a straight line, never while turning.
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 06-21-2010 at 12:20 PM. |
First things first double check the wheel bearings. With the car up in the air or on jack stands grab the top and bottom of the wheel and wiggle it up and down there should be no play. And spin the wheel it should turn freely. If everything checks out okay more than likely you have a blown cv joint.
A blown cv joint will sound like a very loud cliking sound which could be interpereted as a jackhammer. Best way to check it is to drive it on a rack while someone is under the car listening and looking. Easiest way is to hold a long prybar against the chassy and against your ear on each side and find the one that the sound is coming from. Then check for play where the axle goes into the transmission. If there is no play, its safe to say just a bad cv joint. Another easy way to check if its extremly worn is to take sharp left and right turns. Usually it will make sound very prominent on the side thats failing under load. |
| Very loud noise from the engine | Stiv | DIY / Maintenance / Service | 27 | 10-27-2009 10:09 AM |
| strange noise before the car stops | dani1983 | DIY / Maintenance / Service | 14 | 08-15-2009 11:56 AM |
| Random tire thumping noise | Tonavi | DIY / Maintenance / Service | 6 | 06-06-2009 02:27 PM |
| Noise from the drums.... | Lafiro | General Yaris / Vitz Discussion | 18 | 05-22-2009 09:49 AM |
| Radio noise.. need help | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 12-06-2008 04:21 PM |
