| View Poll Results: Do you believe Toyota is an Honorable Company ? | |||
| yes |
42 | 89.36% |
| no |
6 | 12.77% |
| Multiple Choice Poll. Voters: 47. You may not vote on this poll | |||
![]() Drives: 2007 YARIS 3 DR HATCHBACK Join Date: Oct 2008
We own a 2007 Yaris 3dr Hatch back. We have discovered a defect
that Toyota has been aware of since Nov 2007. Toyota made an inproduction change but elected to conceal a impending failure in all previously produced cars...."Total customer care" they call it. If you want to see the proof, email me and I'll send you the internal Toyota Technical Service Buliten.....UPDATE Yaris world CTSCOTT has just posted the TSB list... look at #TSBEG048-07 Last edited by rslyk; 06-25-2010 at 08:50 AM. Reason: another used expanded the information |
Would it happen to be one of these:
http://www.yarisworld.com/forums/showthread.php?t=9753 T-AC001-07(HVAC Odor ) T-AC003-07(Blower Motor Noise & Vibration ) T-BO002-07(Windshield Wiper-Washer Performance Improvement ) T-BO011-06(Parking Brake Lever Dust Boot ) T-EG010-07(M.I.L. ON DTC P0011, P0012, or P0016 ) T-EG032-07(Accessory Drive Belt Noise (Revised) ) T-EG035-06(Excessive Sulfur Odor (Revised) ) T-EG040-07(M.I.L. ON DTC P0335 Only ) T-EG048-07(M.I.L. ON DTC P043E, P043F, P2401, P2402, & P2419) T-EL001-07(IG1 Relay Freezing ) T-EL002-07(Charging System Warning Light ON ) TS-AU001-06(Audio Quick Reference Guide (Revised) ) T-SB-0026-08 (Trunk Lid Full Open Position Improvement) T-SB-0027-08 (HVAC Evaporator Drain Blockage) T-SB-0038-08(Cylinder Head Cover Baffle Precautions) T-SB-0053-08 (Alignment Pin Installation during Transmission Transaxle) T-SB-0065-08 (Blower Motor Noise &Vibration) T-SB-0067-08 (Noise from Auxiliary Port with External Device) T-SB-0120-08 (ABS M.I.L. ON DTC C0210 or C0215) T-SB-0138-08 (Permanent-Type Protective Wax Coatings) T-SB-0142-08 (Upper - Lower Windshield Tick Noise) T-SB-0197-08 (Tire Pressure Warning System Activation ) T-SB-0200-08 (Automatic Transmission Serial Number Locations) T-SB-0201-08 (MY Yaris Pre-Delivery Service) T-SB-0260-08 (Remanufactured Automatic Transmission Serial Number) T-SB-0288-08 (Front Seat Squeak Noise) T-SB-0301-08 (Engine Serial Number Location) T-SB-0302-08 (Special Service Tools) T-SB-0304-08 (Upper Instrument Panel Rattle) TS-BO017-03(Trim Garnish Loose (Revised) ) TS-EG018-06 (ILSAC GF-4 Engine Oil Recommendation) TS-EL003-07(Supplemental Restraint ) TS-EL009-07(Programming OEM Wireless Door Lock Remote Transmitters ) TS-EL010-07(WIRELESS TRANSMITTER & Programming Guide TS-PA001-07(Refinishing Replacement Bumper Covers ) TS-SS002-07(TECHSTREAM ECU FLASH REPROGRAMMING PROCEDURE) TS-ST005-01 (VEHICLE PULLING TO ONE SIDE) TS-SU007-06(Shock Absorber Replacement ) TS-TC003-07(Driveshaft Assembly Replacement ) TS-TC010-07 (World Standard Automatic Transmission Fluid ) TS-TR-0061-W (2008 VIN Decoding) TS-TR-0062-W (2009 VIN Decoding) |
tsb048-o7
OK - So, it's one of the published TSBs. In my 2 years of participating in this forum, I've seen one person mention having this issue, versus the AC odor one, of which probably close to 100 have complained of. Just because there is a published TSB, doesn't mean that every car which that TSB applies to will have that issue. It is to educate the service people of a known potential issue, so they don't have to spend a great deal of time troubleshooting that issue, when a customer comes in. This is standard practice for all car manufacturers.
My only issue with this is that manufacturers typically only address the issue if it is discovered while the car is still under warranty. But, there again, if they didn't use the warranty period as the demarcation, then what would be a reasonable period to continue addressing the issue? |
I believe that the FIRST time that the cars with this are driven for an extended period in a reasonaable heavy rain storm this failure will occur REGARDLESS of period of in
service time. If you look at the replacement parts differences it is clear that they were concerned enough to do a redesign but not honorable enough to offer a $100 update to avoid a $1200 repair that was caused by a known defect. This goes directly to the question of INTEGRITY. This is not a failure of use, wear and tear or expectation of service....I believe it is a continuation of the corporate mentality to dismiss known defects as "OUTSIDE" warranty period. To answer your question of how long....if a change in production is made to correct potential failure and no offer of at customer cost update at "IN DEALERSHIP" major service intervals is made....forever. This is truely an issue of integrity not warranty. Regardless of the number of complaints you have viewed during your participation in this forum.... to dissmiss this defect is not considerate of those folks who have these infected cars and need to be informed so that they make choice of a $100 up date prior to failure. |
#6 | |
![]() Drives: 2007 Join Date: Jul 2009
+1 BUMP TENAZ |
#7 | |
Drives: 07 Yaris 3dr liftback Join Date: Jun 2010
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
It's posted in the thread that I linked to in my post above. It is in regards to the evaporative canister getting saturated with water. The fix is a change to the filler pipe cover.
hopefully by the time you get this you will have seen the list from CTSCOTT
that I am sure will cause Every Toyota dealer in the world to quivering. tsbo48-07 is about < o7 3 door hatch backs....if you have one outside warranty within the vin # range....fix it....then picket a Toyota dealership, they will not take you seriously otherwise. That is my opinion. |
By the way, check out this site, which lists the number of TSBs by manufacturer:
http://www.mycarstats.com/reports/tsbs.aspx |
Take a look at the TSB lists for any car company. Toyota isn't the only company that has to do a little re-engineering after releasing a car or that tries to cut corners in an attempt to maximize profits.
"Honorable"? They are in business to make money, just like every other company. Do they build a good car? In my opinion, yes they do. |
#13 | |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Seriously, are you new to automobiles? These things happen to all makes and models of car, regardless of the manufacturer. You act like it is some kind of life-and-death issue that has killed hundreds of people. It is a service bulletin, your dealership is aware of it and if it's such an issue with you, then take it up with them.
But it is not a recall item, which is what manufacturers do when an issue warrants it. This one does not, so it is handled by a TSB. And can the "honorable company or not" poll, as it is insulting. You are making a mountain out of a molehill, do you really consider that to be "honorable?" Are you really insinuating that Toyota would cut such a minor corner and it somehow saved them millions of dollars? If so, you're worse than the media...
#15 |
MadMax...you must be a Toyota employee...or at least a peson in the
business that thinks that integrity is not a part of business... if my poll insults you then.... I apologise...not for my poll but for your total lack of the concept of intergity. |
#16 | |
As for integrity, I don't think you want to challenge me on that... And learn how to spell...
#17 | |
#18 | |
Obviously you must be a "satisfied customer," because you have the ability to spew such nonsense without someone cracking your ignorant skull in! You're welcome! Now go away, troll; you're giving Texas a bad name!
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| 2007 Toyota Yaris Hatchback - 5-Speed Manual | truebreakerz | Cars for Sale by private party | 23 | 09-17-2009 09:29 PM |
| New Toyota Yaris | jaspie | Australia | 6 | 11-05-2008 09:23 PM |
