Old 07-02-2010, 03:00 PM   #1
jackrabbit
jackrabbit's Avatar
Drives: blue bay
anyone knows if wheel spacer can be placed behind the hub???
anyone knows if wheel spacer can be placed behind the hub??? kinna like PG spacer but i only want 5mm.. dont mind putting it out side but before the hub will be better?? thanks.
world of yarises
jackrabbit is offline   Reply With Quote
Old 07-02-2010, 03:47 PM   #2
33OH
Drives: '08 Yaris
No, the wheel spacer fits your lug pattern, not a 'behind the hub' pattern. And 5mm is fine to use as a wheel spacer.
Old 07-02-2010, 04:17 PM   #3
inside or outside, makes no difference in performance. easier to change out the outside ones, but anything more than 5mm requires a longer stud to go with it.
Old 07-02-2010, 06:41 PM   #4
jackrabbit
jackrabbit's Avatar
Drives: blue bay
kewl..can i add atleast a washer before the hub..around 3mm... i was told the left yaris is 3-5mm off fr the right. thanks guys..
world of yarises
Rear Hub Spacer camber? SweetRS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 08-26-2009 04:10 PM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 01:05 AM
Looking for yaris aftermarket racing wheel hub adapter, and extender wholenizz Cosmetic Modifications (Exterior/Interior) 6 06-10-2009 08:07 AM
steering wheel hub adapter yrsdrgn Cosmetic Modifications (Exterior/Interior) 0 02-25-2007 11:14 PM
