Old 07-15-2010, 04:17 AM   #1
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
need help to remove crap from vehicle
hi people
please help because im going to kick the crap out of a panle beater, had the car washed yesterday, and my daughters finger prints are not coming of, why because the panel beaters some how got clear coat on my windows, now the windows look dirty even when they clean because of the dust that was on the windows, what can be use to remove it, both front and rear door windows have it
they put some thing on the front grill, and now its all over the engine, can i just do an engine wash or should i rather take it in to get washed, will it start if i use a pressure washer,
thanks
www.justbabynappies.co.za
nazier is offline   Reply With Quote
Old 07-15-2010, 05:28 AM   #2
bkndacn
bkndacn's Avatar
Drives: 2009 Toyota Yaris
I dont know much but I've been told not to use a pressure washer on any engine!
bkndacn is offline   Reply With Quote
Old 07-15-2010, 11:50 AM   #3
big lo
big lo's Avatar
Drives: 2007 VIOS
Well the dealers here in PR use the pressure machine to clean under the car and the machine, I had no problem so far, and I clean my engine every month, no problem. I live by the beach and this needs to be done from the sand and salt particals that are in the air, hope you can resolve this situation, holla.
Old 07-16-2010, 04:02 AM   #4
nazier
black shark
nazier's Avatar
hi big lo
thanks will stop later at the car wash,
Old 07-15-2010, 12:06 PM   #5
Billiam
Drives: '10 White Yaris 4D LB
Not to sound stupid....but what's "panle beater"?
As for the windows? Spray them with lots of window cleaner, then use a razor blade to remove the gunk. Keep spraying the window as you work to lube the blade.
Another trick is to use some "0000" grade steel wool to buff the glass. Just make sure it's "0000" (as in 4 zeros)...nothing more coarse.
If you want to enjoy your car, stay off of the internet.
Old 07-16-2010, 03:59 AM   #6
nazier
black shark
nazier's Avatar
hi no question to stupid unless ask twice, its an autobody repairer, they do minor and major repairs to accident vehicles, will try this today
Old 07-17-2010, 09:28 AM   #7
Billiam
Oh..gotcha..."panel beater". The spelling threw me off. Panel beater = autobody tech in my neck-of-the-woods.
Old 07-15-2010, 06:14 PM   #8
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
Panel beater = autobody worker, specializing in making new body parts out of sheets of metal, usually with some sort of hammer or dense piece of wood and of course the legendary English Wheel.
Yarisduder is offline   Reply With Quote
Old 07-16-2010, 12:43 PM   #9
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
try using paint reducer or paint thinner apply to small towel or rag and do small areas at a time used it a while back after getting paint overspray on my windows and used claybar or light polishing compound on the painted area
OTA'sTOY is offline   Reply With Quote
Old 07-16-2010, 09:11 PM   #10
severous01
anything on glass....needs a razor. simple, easy, quick, no need for chemicals or thinners....just a razor.
Old 07-17-2010, 04:37 PM   #11
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
downside of using razors use risk scratching glass
Old 07-18-2010, 04:59 PM   #12
sidewinder
"Gettin Jiggy wit it"
sidewinder's Avatar
Drives: 09 Yaris " S " Hatchback
pressure washing engine
I would not recommend pressure washing, there are way to many things you can mess up. Use a garden hose with a descent spray pattern, but not pressure. you can degrease, but again keep it light pressure and stay away from the electronics, intake, ECU, etc...
sidewinder is offline   Reply With Quote
How the crap do you remove the Rear Cushion???? Focus_Sh1ft Performance Modifications 7 04-27-2010 11:17 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
problem car conurebuddy General Yaris / Vitz Discussion 23 04-11-2009 12:37 AM
