Old 07-18-2010, 09:04 AM   #1
Yarus Maximus
Drives: 2010 Yaris 5-dr auto
is 5000 miles too long to wait for an oil change?
Why does Toyota recommend a conventional oil change at 5000 miles for the Yaris? Every other car I've owned required a conventional oil change at 3000 miles (or 5000 if synthetic).
Yarus Maximus is offline   Reply With Quote
Old 07-18-2010, 09:33 AM   #2
britishbikes
Drives: 2008 Yaris Sedan
I think the 3000 mile interval is for Super Lube to make more money. A car that is driven in normal conditions does not need that frequent of an oil change. If you drive at high speeds, or pull a trailer then the interval should be reduced. The Dodge Ram truck owners manual goes into detail about this because trucks tend to pull heavy weight, etc. The oil change light on my car comes on at about 4500 miles, and the oil still looks fairly clear; the level is still at the full mark. I just checked the valve clearances at 82,000 miles and they are all still within spec, so there does not appear to be any noticeable engine wear. Valve cover pretty clean, almost like a motorcycle engine in there it was so clean. I have a MT '08 Sedan w/TRD suspension, it gets driven pretty hard on the twisties about twice a month including a couple of jumps, I run about 77 mph on the interstate for 400 miles per week, redline the engine frequently.
britishbikes is offline   Reply With Quote
Old 07-18-2010, 09:36 AM   #3
britishbikes
So in a short answer, no 5000 miles is not too long for a Yaris, especially driven like most people drive. The car appears to have very good blowby control; very little contaminants get into the oil.
Old 07-18-2010, 10:18 AM   #4
custom Lftback
custom Lftback's Avatar
I change mine every 7500 miles with fully synthetic oil. No problems!
C-Lift
Old 07-18-2010, 10:24 AM   #5
big lo
big lo's Avatar
Drives: 2007 VIOS
I dont think that is a problem, I allways change mine to 5000 to 6000 and my car has 58789 miles and with no problems at all.
Old 07-18-2010, 12:52 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
That's "old school" thinking. Following toyotas recommended oil change interval is just fine.
Old 07-18-2010, 01:04 PM   #7
Hershey
no problem with a good 5w-30 conventional oil such PENNZOIL ( now rated SN ) , HALVOLINE , etc..
Old 07-18-2010, 01:10 PM   #8
127.0.0.1
3000 miles change is an old recommendation when engines and
oil formulas were built to less exacting standards. that crap doesn't
apply anymore, but oil change places put the fear into you so they make more loot
follow the owners manual.
if you use mobil 1 go to 10,000 miles before oil change
Old 07-18-2010, 01:46 PM   #9
MadMax
MadMax's Avatar
This.
Oil is a precious and limited natural resource, and people are pouring it away because of some outdated information. Luckily some of it can be recycled, but it would be better to use it to its maximum extent than to needlessly change it because of ignorance!
Old 07-18-2010, 02:08 PM   #10
BailOut
Steals terrorist's lunch
BailOut's Avatar
This.
Well said! And there are "extended performance" blends out there that let you go all the way to 15k miles between drain intervals. I've been doing this along with a high performance filter since the first change and things are running fine at 65k miles. I have yet to find any metal on the magnetic drain plug.
- Brian
Share the Road
Old 07-18-2010, 04:47 PM   #11
sidewinder
"Gettin Jiggy wit it"
sidewinder's Avatar
Drives: 09 Yaris " S " Hatchback
5000 mile oil change
5000 miles on an oil change, it depends on how much you love your car. Yes todays engines are better built then long ago, I was a mechanic then and still am. I also worked in an oil testing facility in the military. There is more break down of the oil the longer you use it, except synthetic oil. Toyota does not make any money from you by having engines last 500,000 miles. They want the engines to wear out sooner so they make more money. I did my first oil change on my "S" liftback at 1800 miles and my routine oil changes are at 2500 miles. Oil is cheap,engine work is not. Yes, you believe what you want to. Our 1.5 is a small motor that works hard and makes alot of heat. I have tested oil for many engines in a lab environment. Its science, not speculation.
sidewinder is offline   Reply With Quote
Old 07-18-2010, 06:45 PM   #12
yarrr
Drives: 07 sedan
Well the yaris has been proven to go 400k miles with 5k intervals. 80 extra changes over that period is ~1500-2000 bucks. I could get a salvage engine and install it for half of that. Oil is not cheap, and BP just let the rest of the "cheap" oil flow into the ocean... lol
yarrr is offline   Reply With Quote
Old 07-19-2010, 08:33 PM   #13
ctrj
Drives: 07 Yaris Sdn, 97 4Runner
Use Amsoil and go 15k miles.
This.
RJ
2007 Toyota Yaris Base Sedan -5 speed
SOLD
ctrj is offline   Reply With Quote
Old 07-18-2010, 01:11 PM   #14
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
I think it depends which filter you use.
Fram Tough Guard has a change interval of 7500 miles. I use this one.
http://www.fram.com/oil-filters/tough-guard.php
Fram Xtended Guard has a change interval of 10000 miles.
http://www.fram.com/oil-filters/xtended-guard.php
salmonz is offline   Reply With Quote
Old 07-18-2010, 01:38 PM   #15
Billiam
Drives: '10 White Yaris 4D LB
Thread locked in 3, 2, 1......
If you want to enjoy your car, stay off of the internet.
Old 07-23-2010, 04:49 PM   #16
Billiam
Old 07-18-2010, 08:40 PM   #17
RedRide
RedRide's Avatar
It all has to do with marketing.
Auto manufactures want to claim that their cars are more maintainence free and "greener" than the competition.
Bottom line, it's your car, you are paying for it so, change the oil when you want to.
Personally, I change my oil about every 3k miles or so.
Old 07-19-2010, 09:06 AM   #18
PhillyG
Drives: 2009 Yaris
Amen brother! testify!.... YOU bought the car.. toyota does not own it anymore.. You do what YOU feel is right..
PhillyG is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Dealer oil change boggydee DIY / Maintenance / Service 16 06-30-2010 11:21 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
Dealership wants $64.99 for Oil Change? ScottFern DIY / Maintenance / Service 15 09-21-2006 10:49 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
