Old 07-18-2010, 02:24 PM   #1
KRAZGRL
Crazy Girl (Kasey)
KRAZGRL's Avatar
Unhappy "Clunk" When Turning
I have a 2009 3-door with 14,750miles (I'm taking her in this upcoming week for the 15K)
I have noticed in the past 2 weeks that when I have the wheel completely cranked over to the left I hear this loud "clunk" when I accelerate from a stop. (Like making tight U-turns or turning into a parking space). It will also happen in reverse when the wheel is cranked over. I tested it out and it's fine for tight right turns.
Does this sound like it could be a CV boot issue? I'm going to try to investigate under the car again today to see if I can see anything torn, but haven't noticed anything when I checked a few days ago.
Now, I noticed this clunking sound shortly after I was forced to straddle debris on the freeway from an accident. I think I straddled someone's tail light... So, I don't know if that was the culprit.
I'll be bringing this up when I take it in for the tune up, but peace of mind is always nice when I commute 50+ miles several times a week.
Any input is quite welcomed.
Old 07-18-2010, 05:06 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Could be a bad strut bearing or mount.
Old 07-18-2010, 06:55 PM   #3
KRAZGRL
Crazy Girl (Kasey)
KRAZGRL's Avatar
That's what I'm wondering.. I jacked the car up today and looked at all the boots and everything is fine. No signs of trauma or any kind of leakage anywhere.
Old 07-18-2010, 08:13 PM   #4
Cutie Pie #2
Drives: 2014 Honda CR-V LX
This has happened to my husbands van (not the yaris) it ended up being a bad wheel bearing they just repacked it, now the other one is doing it (should have gotten both done at same time).
My Yaris was doing something similar like that on turns, I took it in and they found rocks in the brake rotor area.
Cutie Pie #2 is offline   Reply With Quote
Old 07-19-2010, 09:19 AM   #5
127.0.0.1
bad bearing, or bad cv joint, loose strut
should get professional diagnosis, or you may end up with one
wheel busted and non-steerable if something is going bad
Old 07-18-2010, 06:43 PM   #6
yarrr
Drives: 07 sedan
Don't turn your wheel all the way, especially while stopped. Its hard on the power steering and dangerous. I make U-turns on 2 lane(each way) roads and when I start moving the wheel is still straight. Also, if your wheel is turned while you are stopped, and you get rear ended, you get pushed into oncoming traffic.
If its only one direction it sounds like you tweaked your P/S rack from slamming it on U-turns.
yarrr is offline   Reply With Quote
Old 07-18-2010, 06:53 PM   #7
KRAZGRL
Crazy Girl (Kasey)
KRAZGRL's Avatar
I don't sit with my wheel turned... lol And I don't "slam" it on U-Turns or any turns. There are times where you just need to make a tight turn.
I was just giving an example. If I am turning into a parking space (or in the process of making a U-turn) it will make this sound. Even backing out of a tight spot where I have to turn the wheel to back up at an angle.
It never has made this sound before. It's not like I changed my driving.
Old 07-19-2010, 09:17 AM   #8
127.0.0.1
how in the HELL did you speculate all this from the OP ?
lay off the chronic, dude
Old 07-19-2010, 03:40 PM   #9
yarrr
Drives: 07 sedan
That's how. There's multiple posts on here, and anywhere you look on the internet stating the damages from turning the wheel all the way to the lock.
Do you have anything useful to post, or just trolling, as is your MO these days.
Old 07-19-2010, 05:02 PM   #10
KRAZGRL
Crazy Girl (Kasey)
KRAZGRL's Avatar
Oh geeze... People need to stop reading into the wording and just imagine the scenario.
I used that terminology to let people know it's not just in simple turns... I don't have the wheel completely LOCKED over to the left, just more over than the typical 90 degree (or so) turn of the wheel, like for most turns at a street light.
Here:
Imagine.. you are waiting for a parking space on the left row. You are stopped so the car can pull out. Then you slowly pull up and turn LEFT (obviously you need to "crank" the wheel over more than you would for a turn at a light). As you begin to accelerate to move into the space.... "CLUNK".
Maybe a diagram would help others...
Old 07-20-2010, 02:11 PM   #11
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Whoa... Farrrr outttt !!! Whatr we smokin here?
Sounds like more like a loose nut upstairs, if you ask me...
bobolinko is offline   Reply With Quote
Old 07-20-2010, 04:10 PM   #12
KRAZGRL
Crazy Girl (Kasey)
KRAZGRL's Avatar
Seriously, huh?
Old 07-22-2010, 01:08 AM   #13
Lucas13
Drives: 07 Yaris LB
Power Steering? The Yaris doesn’t have one...
Lucas13 is offline   Reply With Quote
Old 07-22-2010, 05:45 PM   #14
yarrr
Drives: 07 sedan
Is this the troll yarrr thread and nobody told me? Maybe you should read up on the threads about pulling the P/S fuse to disable it, or read your manual, or look under the hood once in awhile.
Sorry for the negativity, but I called the problem and the cause, and I got nothing but "oh you're must be smoking something" from 2 people, and flak from the OP(whose problem I solved without a trip to the dealer)
anyways, problem solved, lessons still not learned, really out this time
Old 07-22-2010, 08:59 PM   #15
127.0.0.1
but but but MY CAR DOESN'T DO DAT
Old 07-23-2010, 12:40 PM   #16
Lucas13
Drives: 07 Yaris LB
Dont get me wrong Im not making fun you, I had no idea about the other threads.
Old 07-26-2010, 01:43 PM   #17
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
yes it does
E.P.S
electric power-assist steering
any car owners should really read their owners manual and learn to appreciate
the workings of their car
OTA'sTOY is offline   Reply With Quote
Old 07-19-2010, 09:31 AM   #18
Yarus Maximus
Drives: 2010 Yaris 5-dr auto
Take it to service immediately! You are covered up to 35k miles.
Yarus Maximus is offline   Reply With Quote
Clicking Noise while Turning Bella Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 06-12-2010 01:13 AM
2006 Yaris clicking/clunking when turning heistp General Yaris / Vitz Discussion 1 10-13-2009 09:48 AM
Humming noise when turning the steering wheel!! Help?? mhkritzinger DIY / Maintenance / Service 7 09-28-2009 08:27 AM
Noise when turning acuraphile DIY / Maintenance / Service 3 07-22-2009 02:25 PM
Side Turning Signal ttufrosty DIY / Maintenance / Service 25 08-29-2007 01:33 PM
