Old 08-04-2010, 11:52 PM   #1
sleey0
Drives: 2008 Yaris LB
Amp ground
Going to be installing my amp this weekend but wanted to make sure that I won't be drilling into the gas tank.
I plan on using the metal surface that is under the middle section of the rear seats in the back (around where the metal frame that holds the rear seats is, just below it but above the spare tire area).
Can someone confirm that this location is ok? Anyone with any other interesting places to use for ground?
THANKS!
sleey0 is offline   Reply With Quote
Old 08-04-2010, 11:54 PM   #2
sleey0
Just to add that I never owned a hatch and the trunk space makes things like this very interesting to say the least. lol
In my 98 mustang I had plenty of places to place the amp and drilling the ground wire.
Old 08-05-2010, 09:17 AM   #3
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I grounded off to the driver's side of the back seat area. I made my own ground bolt. The fuel tank is under the center of the back seat on the sedan, I'm sure it's similar for the LB. Take a look at some of our install logs, you might gain some insight.
― Thomas Paine
Old 08-05-2010, 09:25 AM   #4
sleey0
Allright, thanks!
Where are the install logs you are referring to?
Old 08-05-2010, 09:58 AM   #5
severous01
you can't find an existing bolt or screw? hell, mount to the shock tower, seat bolts or seatbelt bolts if you have to.
i'd do just about anything before i put a hole in the chassis. once it's there it'll start to rust immediately, then you have a rusty hole in the floor of the car.
there's gotta be a bolt somewhere reasonably close...or you can mount it somewhere else i'd say.
Old 08-05-2010, 11:01 AM   #6
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
You won't believe how many holes I found in my Yaris when I was deadening the floor.
Would recommend sanding the paint off.
D.
CLA 250, 4MATIC
Old 08-05-2010, 04:17 PM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Look on the main menu of this section. Look at Derick's install as well as mine. You'll see lots in there that might work for ground points.
― Thomas Paine
Old 08-05-2010, 05:31 PM   #8
sleey0
Thanks everyone.
About drilling a hole, i never in all the cars i have done it to had it rust. It is inside the car and unless you are spilling water all over, it wont rust.
Old 08-05-2010, 07:56 PM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The frame for the rear seats should have an adequate bolt for you to ground to.
― Thomas Paine
Old 08-05-2010, 09:07 PM   #10
sleey0
Thanks, sq.
That is what I was thinking of using. Easier than drilling, that's for sure.
ok, so where the hell do I ground my amp?? CtrlAltDefeat In Car Entertainment + Electronics (audio / video / alarm) 9 03-17-2010 12:06 AM
How to ground my Amp on Yaris Hatchback charleschia1986 In Car Entertainment + Electronics (audio / video / alarm) 35 11-20-2009 03:13 PM
Quick advice needed on unfinished amp install GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 15 01-15-2009 11:03 PM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
