Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 08-14-2010, 06:13 PM   #1
syntax
syntax's Avatar
sound deadening project
mga kayaris tanong lang po, na experience nyo na ba, or napansin na medyo maingay ang mga yaris natin, i mean dinig na dinig nyo ung outside noise, any suggestions on how to lessen the noise? may mga na research ako dito sa yarisworld tulad nito,
http://www.yarisworld.com/forums/sho...ound+deadening
pero san kaya makakakuha ng materials na ganito? are there other alternative? any suggestions mga kayaris?
Old 08-14-2010, 06:37 PM   #2
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol you may try roof insulation meron d2 nyan sa mga hardware,.. material contains of fiber (some are foam) covered (one side) with aluminum lining.. maybe you can use this as an alternative
duke_afterdeath is offline   Reply With Quote
Old 08-15-2010, 04:12 AM   #3
syntax
syntax's Avatar
effective kaya ung mga un? nakikita ko kasi nilalagay ata un para sa insulation lang sa init hindi para sa mga tunog. lagyan ko kaya ng parang carpet ang buong trunk area?
Old 08-15-2010, 09:05 AM   #4
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
IMHO... pwede ito tol ACOUSTIC Fiber, dual purpose ito for heat and sound proofing. Medyo makapal nga lang kaya siguro hindi ito ginamit gaya ng nasa link, pero pwede ito. Kung carpet nman, dapat malapatan mo lahat pati yung sa reserbang gulong. Mahirap magpatay ng tunog mga bro's, maraming factors na dapat i-consider. Kaya sa DIY na ito puro trial and error ang mangyayari hanggang makuha mo yung gusto mo, until sa buong sasakyan nabalutan na gaya NILA. I could help pagdating dito.. we just need to find some acoustic material that we could use to dead the sound inside our yarii.
Tol, try mo kaya lagyan ng comforter(2 or 3) yung buong trunk mo.
jonimac is offline   Reply With Quote
Old 08-15-2010, 04:56 AM   #5
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Iniisip ko rin gawin to pag napalitan ko na ang muffler.
rye7jen is offline   Reply With Quote
Old 08-15-2010, 07:29 AM   #6
syntax
syntax's Avatar
effective kaya ung parang carpet or carpet mismo na lang ang ilagay ko ung medyo makapal, may effect kaya un para ma lessen ang ingay?
Old 08-15-2010, 09:26 AM   #7
syntax
syntax's Avatar
pre, para mabawasan ba ang sound kailangan halos lahat ng area ng sasakyan? hindi ba naka concentrate ito sa may trunk space?
cge pre experiment muna ako. lalagyan ko ng mga comforter ung trunk ko, ilalagay ko dun ung mga lumang comforter ko hehehehe,
Old 08-15-2010, 11:31 AM   #8
jonimac
jonimac's Avatar
Ganito yun bro... kasi kung gusto mo totally mabawasan yung outside noise IDEALLY dapat LAHAT, I mean buong sasakyan. Kung nakita mo na SILA, lahat nang gumawa nito, mapapansin mo buong FLOORING, from the TRUNK to the DASH BOARD(under), tinapalan nila. After that yung PINTO(all doors) naman nilagyan din ng SOUND absorbent material. Masyadong madugo ito, pero worth the effort naman sa palagay ko. Since manipis ang kaha ng mga Yaris natin, wala tayong kawala sa external sounds, kaya NILA ginawa ito EXPERIMENTALLY. In our case, we will try it one after the other, normally sa TRUNK talaga nagsisimula then papasok sa loob. Technically, kung sa TRUNK lang tayo, for sure mababawasan ang sound coming from the back especially the MUFFLER. Pero yung ROAD noise which is coming from the FLOORING, nandun pa rin yun KUNG hindi natin ito gagalawin o lalagyan. So, its in our hands - choice kung saan dapat lagyan muna, SILA nga kanya-kanyang style, merong buong flooring(metal side), meron namang PATSI-PATSI lang. Gets mo bro... kaya natin ito.
Old 08-15-2010, 12:50 PM   #9
syntax
syntax's Avatar
@ joni, galing galing kaya idol kita eh, so kelan natin sisimulan ang project na ito? ano kaya pwede noise absorbent material ang pwede natin gamitin?
Old 08-15-2010, 01:48 PM   #10
jonimac
jonimac's Avatar
Like I said bro, TRIAL & ERROR DIY ito, GASTOS - meaning pag di umubra yung mabibili natin, TRY nang iba, hanggang sa makuha natin ang gusto natin. Okay... hanap tayo nung ROOF insulator gaya nang nabanggit ni duke, meron nito self adhesive kaya madaling ikabit. Nakagamit nako nito sa SUB-LO box(home made) ko na naman ginamithehehe. Pangalawa, kailangan natin ng LILIM, mainit pa ngayon may katagalan din ang pagkakabit nito, kaya nga naisip ko na muna yung mga COMFORTER for the meantime. Kung meron FOAM katulad ng nilalagay sa ilalim ng CARPET, alam mo yun? yung iba-ibang kulay sya na medyo makapal?... mas okay, RUGBY lang katapat nito saka na tayo magtatabas sa mga sobra. So materyales muna tayo saka tayo bibira okay?
Old 08-15-2010, 05:51 PM   #11
syntax
syntax's Avatar
cge pre hanap ako ng ganun na sinasabi ni duke, pero hindi ata self adhesive ung nakikita ko, pero try ko rin,
Old 08-17-2010, 02:27 PM   #12
syntax
syntax's Avatar
@ jonimac, try ko kaya muna ung lagyan ng lumang comforter ung trunk space, bale aalisin ko muna ung cover para sa spare tire then ung spare tire mismo then ilalagay ko ung lumang comforter then ibalik ko lahat ulit, whaddya think? would it lessen the noise?
nakakita na ako nung sinasabi ni duke, hindi sya self adhesive, hindi ko ata ma gets ung sinasabi mo na nilalagay sa ilalim ng carpet, indi pa kasi ako nakakakita nun eh sowee...
Old 08-17-2010, 03:33 PM   #13
duke_afterdeath
tol ung sinasabi ni joni na nilalagay sa ilalim ng carpet hawig din ung sa roof insulation ang pinagka iba lang foam sya instead of fiber
Old 08-18-2010, 01:03 AM   #14
jonimac
jonimac's Avatar
[QUOTE=syntax;502349]@ jonimac, try ko kaya muna ung lagyan ng lumang comforter ung trunk space, bale aalisin ko muna ung cover para sa spare tire then ung spare tire mismo then ilalagay ko ung lumang comforter then ibalik ko lahat ulit, whaddya think? would it lessen the noise?
You got it bro. obserbahan mo tol.
Old 08-17-2010, 03:39 PM   #15
syntax
syntax's Avatar
aahhh ok.. indi ko pa rin magets wehehhehe, pasyal nga minsan ako sa saco baka meron nun dun heheehhe
Old 08-21-2010, 01:53 AM   #16
syntax
syntax's Avatar
@ joni, nilagyan ko na ng comforter ung trunk space pero ganun pa rin baka kailangan cguro kasama pati ung ilalim na upuan ng rear passenger seats..
Old 08-21-2010, 03:52 AM   #17
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
^Hindi kaya iba pa rin ang effect ng pang sound deadening talaga? As what I see from the forums here, naka-stick talaga sa body ng yaris yung material so maybe malaking factor nga siguro kung nakadikit talaga yung pang deadening na ilalagay.
Old 08-21-2010, 08:07 AM   #18
syntax
syntax's Avatar
@rye, actually tinanggal ko lahat ng nasa trunk ( cover at ung spare tire,) as in bare na talaga sya, then nilagay ko ung lumang comforter, then binalik ko lahat on top of the comforter, pero ganun pa rin ang sound. ( baka kailangan bago ang comforter na ilalagay wehehehehe)
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
sound deadening material??? are names worth it? severous01 In Car Entertainment + Electronics (audio / video / alarm) 15 08-07-2010 09:06 PM
Sound deadening questions cast DIY / Maintenance / Service 7 03-16-2010 12:46 PM
