Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 08-16-2010, 05:38 PM   #1
ubospawis
ubospawis's Avatar
Drives: Flint Mica 2010
Tire pressure
How much tire pressure are you using? Nung first na gamit ko I notice medyo nag iiskid when I check the tire pressure it was 45psi, binba ko ng 35psi, medyo nabasan yung ingay ng road and di na masyado makaldag.
ubospawis is offline   Reply With Quote
Old 08-16-2010, 05:48 PM   #2
syntax
syntax's Avatar
as per my experience lang po, 32 front 30 rear ang ginagawa ko, usually ako lang kasi sakay ni shadow eh, kaya preferred ko ung ganun, and besides mainit ngayon so nag eexpand pa sya ng konti.
Old 08-16-2010, 06:57 PM   #3
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
same here tol
duke_afterdeath is offline   Reply With Quote
Old 08-17-2010, 01:18 AM   #4
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
sabi po ng mekaniko kong pinoy, kapag ka ngayong tag-init ay 30psi for both. at kapag taglamig naman at 32psi. tapos ung spare tire ay dapat 35psi.
EjDaPogi is offline   Reply With Quote
Old 08-17-2010, 01:58 AM   #5
syntax
syntax's Avatar
so mostly naglalaro lang sa range na 28psi to 32psi ang mga tires.depende na rin sa preferrence or kung ilang ang sakay ng yaris natin
Old 08-17-2010, 02:09 AM   #6
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
nabasa ko sa net, 34 sa front then 32 sa rear, ewan ko lang kung yun ang best, for me as of now ganun gamit ko kc puno lagi ako ng sakay, medyo flat na kapag binaba ko p dun.
as for my experience nung una kong ginamit ang auto, nagulat ako nung chineck ko pressure, it was 65psi!!!. i thought check muna ng dealer ang pressure bago ibigay, nagamit ko na ng 1 week bago ko nakita pressure, kaya pala maskid then makaldag takbo ko.
xtremist is offline   Reply With Quote
Old 10-18-2010, 03:54 AM   #7
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Just to update this thread.
Napansin ko lang ngaun na parang kulang ang tire pressure ni mica so I made some readings. Both front tires reads 25 psi, 28-30 psi nman sa rear tires. Any comments mga kayaris?
rye7jen is offline   Reply With Quote
Old 10-18-2010, 04:05 AM   #8
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
Natural lang bumaba minsan yan rye, ganun din si minie ko 25psi last time. 32psi dapat base sa manual, pero 30psi lang nilalagay ko. Yun ay akin lang.
jonimac is offline   Reply With Quote
Old 10-18-2010, 04:05 AM   #9
syntax
syntax's Avatar
@ rye actually preferrence na lang ata yan, sakin kasi 32psi ang front at 30psi naman ang rear kasi mas mabigat ang load ng front natin.. antay natin kung "violent reactions" ang iba pa nating mga kayaris hehehehe
Old 10-18-2010, 04:27 AM   #10
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Hindi kaya effect din ito ng weather natin ngaun since nararamdaman ko na ang simoy ng pasko??
Kidding aside, San ba pwedeng magpadagdagng hangin dito sa riyadh? Any suggestions?
Old 10-18-2010, 06:17 AM   #11
jonimac
jonimac's Avatar
@rye any Gas Stations palagay ko merong vulcanizing shop, maki suyo ka lang o ikaw na mismo mag lagay.
@blessed, san merong nitrogen para sa gulong natin? Tnx.
Old 10-18-2010, 07:43 AM   #12
BlessedYaris
BlessedYaris's Avatar
Drives: Yaris Gray "Blessed"
Send a message via Yahoo to BlessedYaris
jonimac... check ka lang sa mga new gasoline station dyan sa ruh, dito kase sa khobar almost yong mga magaganda at mga bagong gasoline station na may mga shop for change oil/ vulcanizing/ tires... basta sabihin mo lang "Nitrogen Air"... alam na nila yon. then suggestion sa oil... Castrol Magna "synthetic oil" yon... mas matining sa makina and laso for 10thou kilometers before ulit pa change oil... yon po ang gamit ko ngayon at very smooth takbo ni blessed...
God Bless !!!
BlessedYaris
0552829596
BlessedYaris is offline   Reply With Quote
Old 10-18-2010, 07:43 AM   #13
bluecris44
bluecris44's Avatar
Drives: Yaris Sedan 2009 - "Angel"
Send a message via Yahoo to bluecris44
@rye: di ka ba nabigyan ng tire air pressure kit? ung kasama sa kit na bigay ng toyota? Un kasi ang ginagamit ko eh...
Guys, pag pinarotate ko ung gulong ko eh... pano ang rotation ko nun? clockwise b? ung nasa unahan eh malilipat sa likuran?
“When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others.”
bluecris44 is offline   Reply With Quote
Old 10-18-2010, 08:03 AM   #14
syntax
syntax's Avatar
sa tire rotation naman sa pagkakaalam ko, you can try crisscross method, ung front right papunta sa rear left then ung front left sa rear right, this way magiging even ang treadwear ng mga tires ni angel. idk if ito ang method ng mga kayaris natin, antay tayo ng feedback galing sa kanila.
Old 10-18-2010, 08:18 AM   #15
bluecris44
bluecris44's Avatar
Thanks Syntax! Ikaw na talaga!
Old 10-18-2010, 09:02 AM   #16
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@bluecris, What do you mean by kit? tire pressure reading pen lang meron ako.
Old 10-20-2010, 06:50 AM   #17
duke_afterdeath
rye meron tayong emergency kit kasama dun ung portable na compressor..
Old 10-20-2010, 06:55 AM   #18
jonimac
jonimac's Avatar
Tol, parang wala sila nun, kasi si syntax ang alam ko bumili pa.
Higher tire pressure and winter handling? TwoBearWisconsin Fuel Economy Forum 15 03-01-2010 09:14 PM
recurring loss of tire pressure toad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-10-2009 04:54 PM
Tire pressure sensors ztlonewolf DIY / Maintenance / Service 14 04-25-2009 05:19 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
