Old 08-21-2010, 09:17 AM   #1
rtom
Drives: 2010 Yaris 3-door liftback MT
rhythmic hum from engine at highway speed
Does anybody else hear this?
My manual transmission 3-door LB with about 11000 miles on it is making a humming sound that modulates with a cycle time of 3-5 seconds. I don't know the right musical terms, but here's an approximation:
HUMMMMMMmmmmmm HUMMMMMMmmmmmm HUMMMMMmmmmm
where the all-caps means louder and small-caps means less loud. It's a vibration of some kind that is coming from the front of the car, probably the engine or transmission, and it only occurs under load and at 55+ mph. If I push in the clutch, it stops.
I know funny little noises can be very hard to diagnose, but thought I would ask. I don't think I heard this when it was new.
Also, after the second oil change it is less loud.
rtom is offline   Reply With Quote
Old 08-21-2010, 09:51 AM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Mine has done that since the day I took delivery. Just as you say it only occurs at 55 plus. I have an auto which I suspected had something to do with it, but apparently not. Not a big problem for me but I too found it interesting.
-The Fitful One
Old 08-21-2010, 02:31 PM   #3
craigq
Drives: '07 Yaris, '12 GLI
My automatic sedan also has the 'highway hum'. I can't recall if it has it with the winter tires on or not. Still using the OEM Potenzas for the spring/summer/fall...
craigq is offline   Reply With Quote
Old 08-21-2010, 03:54 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
What tires do you have? Mine did that at first with the 15" goodyears, stopped when they wore down a bit and now I only use the stockers in the winter.
Old 08-22-2010, 01:37 AM   #5
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Most likely hum from two tires that are of slightly different diameters, or rotating at slightly different speeds from a slight curve of the road, so the hum is slightly out of synchronization, alternately reinforcing and cancelling.
Old 08-23-2010, 06:12 PM   #6
brg88tx
Drives: 07 Yaris Sedan, Auto
my auto sedan does this too. imo it's not from the tires. i think it's from the engine or transmission.
brg88tx is offline   Reply With Quote
Old 08-23-2010, 07:22 PM   #7
Yaribusa
Yaribusa's Avatar
Drives: 2010 Yaris 3 Door Manual BSP
I have about 500 miles on the new Yaris, and I noticed this last night. Mine is a 2010 3dr Manual and I noticed it at about 55 MPH. The noise did go away when I engaged the clutch. It kind of reminded me of a small airplane, but it was not loud enough to be an issue at all.
Yaribusa is offline   Reply With Quote
Old 08-25-2010, 11:48 PM   #8
ajae
Drives: 2007 Yaris 5-door hatch
I have the same hum on mine as well. I don't always notice it, so I wonder if it's some kind of resonance being set up somehow in the engine/tranny/torque combination. 75,000 miles on my '07 Yars.
AJAE
2007 Yaris RS Hatch, Eibach Springs and Borla Exhaust Canadian Dealer options
1981 BJ42 LandCruiser all stock
Love my toys!
ajae is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
engine swap update Adriaan Canada 5 03-03-2009 06:21 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
