Old 12-12-2006, 12:11 AM   #1
RSboyz
RSboyz's Avatar
Drives: 2007 Yaris RS
Changing Headlight Bulb Tutorial
Hey guys, correct me if im wrong, but i think i remember reading a thread about changing headlight bulb tutorial in the forum before, and im planning to change my bulbs this weekend, so i want to find the tutorial and read about it. oh and if you guy have any opinion or idea about the bulbs, throw them in here and i will be happy to hear about them.
Im planning to get the PIAA H4. is there a blue coating on the bulbs? and i have fog lights as well cuz of the RS model, not sure if the white light from the headlight would match the stock yellow light from the fogs
RSboyz is offline   Reply With Quote
Old 12-12-2006, 03:37 PM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I think all the PIAA's have a coating.
I'll be pulling these out of my brand new fog lights and will likely offer them here cheap. If your fogs take H3, you might want to buy them from me to better match your headlights.
Old 12-12-2006, 04:25 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
FYI - your factory owners manual explains how to change evey bulb in your Yaris.
Old 12-14-2006, 01:32 PM   #4
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Really?I have some reading to do!
Old 12-12-2006, 07:50 PM   #5
RSboyz
RSboyz's Avatar
i read it and since my car is not here with me and those diagrams are shitty so i dont have a picture of the headlight unit in my head in order to understand them or maybe im just too neewb.
Violin: is it hard to change the fogs? because in the manual it said bring it to the dealer if you want to change them because you may damage the vechile.
Old 12-12-2006, 09:08 PM   #6
bigsky2
Cousin Vitz
bigsky2's Avatar
The headlights are quite easy to change.
It's a bit of a pain because there is not much room between the rear of the lens assembly and the other engine components for your hand to maneuver and remove the light bulb.
Patience and persistance will get it done in 5-10 minutes.
Remember to wear gloves. If you don't have gloves, don't touch the glass area of the bulb.
To change fog lights:
1) Jack up the car (optional to an extent)*
* make sure it's supported by jack stands - SAFETY FIRST!
2) If your head is not too big and you are slim, and if you can squeeze your head and shoulders under the front bumper under the fog light, you are good to go
3) Take off the 3 bolts that hold the lower splash guard to access the fog light assembly
4) Disconnect fog light, twist fog light out
5) Replace with new fog light, reconnect molex plug
Old 12-12-2006, 09:51 PM   #7
RSboyz
RSboyz's Avatar
that sounds pretty easy, but i never done it before and im always afraid i do something wrong and damage my car
Old 12-12-2006, 09:53 PM   #8
Chris07LB
Chris07LB's Avatar
Take it to the dealer then.
Old 12-13-2006, 02:59 AM   #9
ChinoCharles
Drives: LB
Don't be scared, it ain't a bimmer.
Old 12-13-2006, 07:26 PM   #10
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
i just had some one do it if you bring the balbs when you get your oil changed they'd do it for free
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 01-09-2007, 05:06 PM   #11
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
I just changed the bulbs with the Osram or w/e...um didn't use a glove...hahaha well I had sum1 else help me..anywa what happen if u don't use gloves?
-- Blen
Old 01-09-2007, 05:28 PM   #12
Violin
Violin's Avatar
Oils from your hands will cause them to burn out really fast. Take them out and clean them with isopropyl alcohol and reinstall them using gloves.
Old 01-09-2007, 05:49 PM   #13
Chris07LB
Chris07LB's Avatar
Think of it as practice, as your going to be pulling them soon, once they blow.
Take V's advice, and clean them before that happends... and to answer your next question, you can buy the isopropyl alcohol at any food store, or pharmacy.
Old 01-10-2007, 02:46 PM   #14
Katana
Katana's Avatar
You have the answer for every question!
Old 01-10-2007, 07:57 PM   #15
Chris07LB
Chris07LB's Avatar
ok. wait, was that a question too?
Old 01-11-2007, 03:04 AM   #16
spkrman
Drives: 1
swapping the bulbs is not for those with big hands...
some blood sweat and tears later... I got mine swapped out, but it was so extremely hard to fit my fat hands in there.
The manual is very vague... but it tells you enough so that you can do it.
Old 01-11-2007, 11:24 AM   #17
Blenjar
Blenjar's Avatar
Damn...burn them out huh...well I'll change them next monday when I get my fog lights...I mean I have to take the bumper off right?
-- Blen
Old 01-11-2007, 02:58 PM   #18
bigsky2
Cousin Vitz
bigsky2's Avatar
If you are installing fog lights, then I believe you have to remove the bumper to accomodate and route the wiring.
But if you are only changing the bulbs for the fog lights, removing the bumper is not necessary.
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 07:40 AM
Accessory Bulb Types, anyone know? Ayka Cosmetic Modifications (Exterior/Interior) 135 04-29-2007 09:33 AM
Quick headlight question silverRS Cosmetic Modifications (Exterior/Interior) 3 06-21-2006 10:54 AM
