Old 08-29-2010, 05:09 PM   #1
roadrunner
Yaris Hypermiler
roadrunner's Avatar
Drives: 2007 Silver Liftback
Question about Tire Size
I have the OEM 15" steel wheels. Can I put 195/65R/15 tires on the rims without any problems. I have a chance to purchased 4 almost new (4000 miles) Blizzaks.
roadrunner is offline   Reply With Quote
Old 09-02-2010, 04:14 AM   #2
ddongbap
You, however, can be super cool and run at a lower PSI so you can shrink those tires a little.
Old 09-02-2010, 03:32 PM   #3
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
My dad just bought that size and put them on his '08 sedan. He says he has no rubbing but I think he will have some when he goes on a extended road trip packed down with luggage. They look ok, just a little stuffed. I can try and take a photo!
JTDBT903 is offline   Reply With Quote
Old 09-02-2010, 08:45 PM   #4
severous01
u cld run blizzaks in the winter fine with the 65 series tire...but dont do anything sporty with it. 65 is kinda high for our cars.
196/60/15 is a good size for performance because although a little taller, there are much more 'sport' tires in the selection vs 185 series tires.
but, 60 is higher than stock and putting a 65 series on there is way higher than stock. your speedo will be off, you wont have as much 'torque' off the line because your 'gear ratio' is off with bigger tires, but on the other hand you'll get better mileage if you do a lot of highway.
Old 09-05-2010, 08:27 PM   #5
docB
Drives: '09 Yaris Sedan
In the winter you would get better performance from a narrower tire like a 175/65-15, if it was made. Wider just has to plow more snow.
docB is offline   Reply With Quote
Old 09-06-2010, 06:22 AM   #6
roadrunner
Yaris Hypermiler
roadrunner's Avatar
Thanks for the replys. I am going to pass on purchasing the tires.
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Tire size question Palmer812 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-13-2010 10:47 AM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
Question about tire size with TRD drop. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 01-29-2009 05:30 PM
Tire Size Question Yaristwn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 01-29-2009 01:28 PM
