Drives: 2008 Yaris Hatchback Join Date: Aug 2010
My blower fan housing became full of water because of trash in the drain line. The fan motor was ruined. This car came with NO filter above the blower fan. I also read that Toyota has redesigned a cowell to better clean the outside air intake. I have never gotten a letter from Toyota about this problem. I just turned 37,500 so I guess I'am done for.
How many of you had the same thing. I KNOW I'am not alone. |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
What a drag! I know there's no filter by the blower. I just made one from a pleated filter I use for my furnace. But to get a clogged drain in 37k miles in unusual. Most cars until just recently didnt even give an option for one.It bacame an "indoor air quality " issue within the last 5 or so.
Are you the original owner? maybe alot of dusty roads or something. I asked if you were the original owner cause if a car got wrecked, many times dust from body filler and such is notorious for clogging drains. As far as that goes it could be a dead bug,lol. Good luck. Cost of repair? |
![]() Drives: Toyota Yaris Join Date: Oct 2010
I am now having the same problem, My car was purchased recently at a private dealership, it was used & it has 100,000 km on it. It's also has a list of many more problems. I'm looking into using a filter for the furnace to make a filter by the blower fan, it will have to wait though, I have to get the radiator fixed, the thermostat, and the water pump before I create things to make the car better. Your lucky you don't have these problems. Cheers!
Furnace Filters Last edited by ecenur; 11-02-2010 at 12:14 PM. |
| Whistle at idle - vacuum leak, induction side | RichieRoo | General Yaris / Vitz Discussion | 17 | 12-16-2022 05:53 AM |
| Air Conditioner Noise & Leak? | Dawn Eshelman | DIY / Maintenance / Service | 116 | 07-21-2015 01:22 PM |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| Wine of Water | Benggolf2 | Off-topic / Other Cars / Everything else Discussions | 4 | 12-25-2009 02:01 PM |
| water in the tails? | the_boss | Cosmetic Modifications (Exterior/Interior) | 9 | 02-20-2009 12:53 PM |
