Old 12-13-2006, 11:31 PM   #1
bigsky2
Cousin Vitz
bigsky2's Avatar
Help: Water/Moisture Entered Fog Light Assembly
I noticed one of my fog lights was out this evening and when I looked at the fog light, I noticed moisture inside the lens assembly.
Is the fog light assembly toast now, or is it isolated to just the bulb?
And how would I go about repairing the immediate problem?
I was thinking of using a hair dryer or heat gun to dry out the moisture inside the assembly before connecting a new bulb.
Help please
Old 12-13-2006, 11:42 PM   #2
acrbill
Drives: Polar White Hatch
go right to the dealer and get it covered under warranty.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 12-14-2006, 01:53 AM   #3
bigsky2
Cousin Vitz
bigsky2's Avatar
Well I got a little antsy and decided to check it out myself.
Seems like some water got into the housing via the hose/shield around the fog light wire harness and its shorted the bulb.
Connected a spare H11 bulb after drying the assembly and the wiring harness and it worked fine.
I'm a little surprised that the fog lights are not covered by a rubber boot to prevent water from entering.
I'll see if I can make a boot for the fog light to prevent this from happening again!
Old 12-14-2006, 03:25 AM   #4
Ah, no problem, you're Canadian, you guys are experts when it comes to a boot......
*runs away*
Old 12-14-2006, 08:30 AM   #5
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
will work for parts
vodkalush is offline   Reply With Quote
Old 12-14-2006, 08:37 PM   #6
bigsky2
Cousin Vitz
bigsky2's Avatar
I think I know how water and moisture entered the fog light assembly.
It was snowing for a few days in Vancouver last month and when most if it melted away, my car was filthy.
I took it to an automated car wash and before the main wash began, there was an undercar wash/spray which probably shot some water into the fog light assembly.
Maybe it's time for that C-ONE aluminum under panel
Old 12-14-2006, 10:26 PM   #7
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
theres stuff you can buy to get rid of that at walmart it cheap
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 12-14-2006, 11:19 PM   #8
vodkalush
I drive a yarrrris
vodkalush's Avatar
Like posted above; bring back to dealer and have them pay for a solution... I mean thats why you buy new; for the warrenty
will work for parts
Old 12-18-2006, 04:19 PM   #9
bigsky2
Cousin Vitz
bigsky2's Avatar
I fixed the problem myself and didn't have to bring it back to the dealer.
Just have to find some material to make a boot for the fog lamp as it's completely exposed to the elements...
How boot you help me out there etimago?
Old 12-18-2006, 04:35 PM   #10
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
You might try putting one of those silicone dessicant packs in each lamp if there's room and sealing around the wires with silicone.
Old 12-19-2006, 01:10 AM   #11
Yeah I agree, good old RTV silicone sounds like your best friend here.
tip: If you don't want to have it looking all blobby when you're done, coat your fingers with a very strong soap-water mixture and smooth the silicone by hand.
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 02:18 PM
question on Fog light clfile Cosmetic Modifications (Exterior/Interior) 6 11-09-2006 08:11 PM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 04:06 PM
Fog Light OxyG3nE Cosmetic Modifications (Exterior/Interior) 1 11-01-2006 04:44 PM
Fog light on RS GabL DIY / Maintenance / Service 5 03-13-2006 06:31 PM
