Old 09-24-2010, 08:41 AM   #1
zakasate
Drives: toyata vitz
Delay in picking speed and changing gears
I have an automatic transmission Vitz and I am noticing that when i start off there is a delay in the picking up of speed. i checked the fuel filter i couldn't find one, i checked in the tank the mesh filter in the in the fuel pump it is OK. what could be the problem does this have to do with the fuel system or gear changing system? otherwise when it has picked speed everything is OK its just at the beginning
zakasate is offline   Reply With Quote
Old 09-24-2010, 08:54 AM   #2
throttle lag? we have electric throttles so there's always a bit of a delayed response, most noticeable in this situation of starting to get moving.
Old 09-24-2010, 09:38 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Are you talking about taking off cold? When these cars are cold, acceleartion is slow and changing up gears lags. But, there should bo no problems when the car has reached running temperature.
Old 09-27-2010, 11:13 PM   #4
zakasate
Drives: toyata vitz
Slow in poicking speed
I found out that the Airflow sensor was dead. so i replaced it and everything is now ok.
Old 09-27-2010, 11:57 PM   #5
kimona
kimona's Avatar
Glad you resolved the problem.
