![]() ![]() Drives: toyota yaris sedan Join Date: Sep 2010
INTERIOR FLOOR SOAKING WET
Hi
I have a problem every time it starts to rain the floor in the interior is soak does anyone else have that problem or is it just me. If you have a solution to it would you mind sharing it please because it's starting to bug me |
Have you checked if you have all the rubber plugs in place at the bottom? Sometimes car dealers forget to put them on...
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
Well i check all of them and there in there rightfull place
but i just put some silicon around them but i wanted to know if this happened to anyone else and what was there problem |
Can you notice where it starts?
well no not really because it was mostly the 2 rear floor that was wet
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Mine does the same thing, still unsure as to why.
@33OH
well i tough i was the only one thank god but it's getting to me now because it gives the car a bad scent |
Yeah mine's real musty and gross. It's been doing it for at least a year or two. I took it to a body shop and they couldn't figure it out.
And did you go to the dealer ?
Yes but they blamed it on the body shop because my car was just repaired from a wreck when I noticed it. So they both blame each other and I drive a smelly swimming pool. :)
so in other words no of them couldn't find the problem so they blamed it on each other
How about spraying the car with a garden hose? You should be able to see where the water comes from
#13 | |
but who knows, where the water is coming from? what kind of accident did your car had? did the water started after the repair? ![]() ![]() ![]()
#14 |
It seemed to have started after the repair in my case. I will have to pull the carpet and check, thanks derick.
#15 |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
Had that problem, some of the rubber plugs came off do to constant srapping the bottom of the car (trying to get a F**** parking at the university
) and i did some boddy damage. The dealer removed ALL the interior, they hire a guy to repair it.
I Drive a 129whp Yaris ;) |
#16 |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Maybe it's coming down from the door sills? Check that the seals are tight
#17 |
#18 |
Hi
It's me again this morning i woke up again and i saw it had a little drizzle tru out the night so my roof and a little water on it so when i went in i check the floor and it was a little moist not wet because it didn't really rain so my guest is the water is coming tru the roof does anybody have a idea of way on the roof it can be coming tru because i tried wetting it down n i didn't find where it was coming from ? |
| carpet wet passenger side | dadmansfield | DIY / Maintenance / Service | 28 | 10-04-2022 05:51 PM |
| 205-65-15 wet traction tires | zachryboles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 06-12-2010 02:07 AM |
| Pinging belt when wet or cold | steveh74 | Europe (continental) | 0 | 08-22-2009 05:50 AM |
| Wet float bearings | rkvin21 | Forced Induction Forum | 2 | 07-06-2009 02:09 PM |
| Wet Okole RS/S seat covers!! w/pics! | PaidTimeOff | Cosmetic Modifications (Exterior/Interior) | 2 | 12-04-2008 06:53 PM |
