![]() Drives: 2010 Yaris Sedan Silver Join Date: Feb 2010
GT28 OK for 1.5 Yaris engine?
Is this too much turbo for our cars? Stock internals.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT Reason I ask is it seems everyone goes with the T25 turbos, but some of the more economical e-bay ones do not have ball bearings. This unit on the other hand looks a little better made. Not sure about the compressor side w/72 trim. Too much? |
Never mind. Found all the info. I wasn't searching with the right keywords.
#3 | |
#5 | |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Thanks for the input. I decided to go with the GT25. Seems to be the most popular choice for our little engines. Not looking for more than 6 or 7lbs of boost so I can keep the stock internals. Almost done buying the parts.
a GT30 will work too, but that doesn't make it a good choice (well, it would be good for a drag application).
GT25 will be good and nimble for you.
Here is a link that everyone should take the time to read:
http://www.turbobygarrett.com/turbob...ch_center.html GT this, T that is not the question that should determine the turbo used. Turbos have alot of specs that determine on what size engine it will work best on & how quickly it will spool.... |
Very good link. Thanks. It's been a while since I mess with this stuff. Forgot most of it. Last car I worked on was turbocharging a Ford Focus back in 2000(ish).
yes, but within the Garrett GT family of turbos, it IS a valid question. As long as you are comparing apples to apples, it's a fair comparison.
Further I have PERSONALLY used both the GT25 and 28 in my car, and I know the difference. Next is a GT2871, then I'll know the difference with that too.
Below is all the versions of the GT25 & GT28. If you suggest to someone to use a GT25 that has 3 different versions, or a GT28 that has 18 different versions, without any other info, are you really giving good info?
GT25 GT2554R - 471171-3 GT2560R - 466541-1 GT2560R - 466541-4 GT28 GT2854R - 471171-9 GT2859R - 707160-9 GT2859R - 780371-1 GT2860R - 707160-5 GT2860R - 707160-7 GT2860R - 739548-9 GT2860RS - 739548-1 GT2860RS - 739548-5 GT2871R - 472560-15 GT2871R - 743347-1 GT2871R - 743347-3 GT2871R - 707160-10 GT2871R - 780371-2 GT2871R - 743347-2 GT2871R - 743347-4 GT2871R - 771847-1 GT2876R - 705330-1 GT2876R - 705330-2 |
Sorry Carlos not going to spar with you. There is now enough info on the thread for the OP to understand.
Guess what came in today...
So I already installed the new plugs, Fuel pump arrives tomorrow and I should have the new injectors by Friday. |
| 2007 Toyota Yaris engine assembly | dunetrooper | Items for Sale by private party | 14 | 07-10-2010 08:31 PM |
| Toyota Yaris Engine Map | wariss | Performance Modifications | 5 | 03-15-2009 12:21 PM |
