Old 11-23-2010, 07:41 PM   #1
kingbobby83
Yea..thats mine
kingbobby83's Avatar
Drives: 2009 Yaris Sedan 5 speed
Send a message via MSN to kingbobby83
LEDs???
I am trying to wire up some LEDs in the front floor board under the dash. I jave no problem running the positive wire to a fuse, but I am not sure where to run the ground. Any suggestions on where to connect the wires...and make it look nice. I want the lights to come on when the key is on..for now...
"I'm sorry, were you driving there?"
kingbobby83 is offline   Reply With Quote
Old 11-23-2010, 10:31 PM   #2
severous01
any bolt or screw or nut that's into sheetmetal on the frame of the car. as in, the big metal tube thats under the dash or any metal piece bolted/welded to it. you can run a wire to the seat frame. you can tap into any ground already there (radio or switches or whatever) bolts holding the steering column...
easiest and not recommended but what happens in car installer shops....put a screw through the floor pan. i dont not suggest this as you now have unprotected metal and it will rust.
just find a bolt or nut to unscrew and stick an end thingy on the wire, put it on the nut/bolt and tighten.
Old 11-23-2010, 10:42 PM   #3
kingbobby83
Yea..thats mine
Okay thats what I was thinking...So to set the lights to come on with the ingnition, I need to just tap into the accessory fuse right?
Old 11-24-2010, 10:59 PM   #4
kingbobby83
Yea..thats mine
Got them going...will post pics tomorrow hopefully!!!
LEDs to replace interior lights: Which ones? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 57 04-28-2010 01:44 PM
What can I do with a bunch of these LEDs? eTiMaGo In Car Entertainment + Electronics (audio / video / alarm) 14 05-13-2009 04:28 PM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
Gauge Cluster LED's Kaotic Lazagna Cosmetic Modifications (Exterior/Interior) 11 01-08-2009 12:59 AM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
