Old 11-26-2010, 09:33 PM   #1
p123456789
Drives: 07 lb jeep tj
RABBIT SEAT IN YARIS!!!!
my back couldnt take it anymore so I went on a search to find a seat that would fit in the yars and I found one. I swapped a seat out of a rabbit the bolt holes almost line up I had to drill the rabbit seat holes out one size and the seat bolted in perfectly. the yaris seat hurt my back because its so hard and has no lumbar support and I'm pretty short so the lack of height adjustment made it hard for me to reach the pedals. the rabbit seat has power recline and really nice side bolsters and lumbar adjustment. If anyone is interested in this I can take pictures and give directions. I couldnt believe how much a nicer seat makes the car feel.
p123456789 is offline   Reply With Quote
Old 11-27-2010, 09:40 AM   #2
sex
sex's Avatar
Drives: 09 5DR
pics please
sex is offline   Reply With Quote
Old 11-27-2010, 12:40 PM   #3
p123456789
Old 11-27-2010, 12:45 PM   #4
p123456789
sorry my car is dirty i'm halfway through installing rear speakers and I'm trying to find some cheap dynamat
Old 12-04-2010, 12:31 AM   #5
Uber_Otter
Uber_Otter's Avatar
Drives: Black XA not yaris but close
I use Edead I put it all over in small amounts when I pulled my interior to install speakers and amp. its a $1 a sq foot and elemental designs service has always been good.
http://www.edesignaudio.com/product_...products_id=51
Uber_Otter is offline   Reply With Quote
Old 11-27-2010, 12:48 PM   #6
nice! what year range will work from a golf/rabbit?
Old 11-27-2010, 01:01 PM   #7
p123456789
any 06 and up rabbit gti or jetta, not sure about passats though those seats are even nicer. I tried to find some plaid gti seats but they wernt cheap, I got the rabbit seat for $65 its so nice to sit a little lower in the car makes it feel alot more sporty.
Old 11-27-2010, 01:20 PM   #8
would beetle seats work too?
Old 11-27-2010, 01:23 PM   #9
p123456789
no they have a weird center style mounted seat track.
Old 11-27-2010, 02:31 PM   #10
41magmag41
Drives: Loaded 2007 mica silver sedan
What about the seat belt warning wiring? Does that hook right into the yaris' wiring harness??
41magmag41 is offline   Reply With Quote
Old 11-27-2010, 02:56 PM   #11
This feature works?
Old 11-27-2010, 03:20 PM   #12
p123456789
yes power recline works, that was easy to wire up. The seat belt wiring is both 2 wire so I assume you can wire them up to the seat belt buckle on the rabbit seat but for now I plugged the old yaris buckle into the car and used my dogs seat belt buckle so it wouldnt trip the belt warning chime. I also used new grade 8.8 17mm bolts with washers to hold the seat in.
Old 11-27-2010, 03:21 PM   #13
p123456789
I want to tackle the passenger seat next weekend but I'm not so sure about the airbag sensor in the seat I might just swap it over from the yaris seat it is just a simple weight that turns the airbag on.
Old 11-27-2010, 10:10 PM   #14
The Yaris seats use four sensors on the passenger seat for occupancy detection. The sensors are load cells that connect the upper part of the seat to the lower frame, thus allowing them to weigh the upper seat as well as whatever is on it. If you can transfer the load cells over, you will need to have someone with a Toyota TechStream Tool recalibrate the system for the difference in upper seat weight (unless the VW seats are close to the same weight).
Old 11-28-2010, 01:24 PM   #15
2009BBPliftback
2009BBPliftback's Avatar
Great work following this thread closely!
2009BBPliftback is offline   Reply With Quote
Old 11-27-2010, 03:48 PM   #16
cool project. post up pics when you move that sensor over.
Old 11-29-2010, 07:04 PM   #17
birdman
Drives: '08 Blazing Blue Yaris LB
Great upgrade! Does the lower seating position affect leg room? Can you hook up the airbags in theses seats?
birdman is offline   Reply With Quote
Old 11-29-2010, 07:58 PM   #18
auxmike
auxmike's Avatar
Nice seat, I hate the goofy blue dots in my car.....
wtb: racing seat bracket for yaris hatchback vten Willing to Buy by private party 1 08-03-2009 09:51 PM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
