12-05-2010, 03:53 AM | #1 |
Drives: Black '07 Yaris Join Date: Dec 2010
Little Problem... BIG rip off!!
Is there a specific type of tire iron i need to use on my 07 yaris? they want to charge me $20 per bolt to change my tires!!!! WTF?? so yeah... what do i need to change the tires on my car??? SOMEONE HELP ME!!
12-05-2010, 06:00 AM | #2 |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
If it is a stock set up you should have what you need in the trunk. Otherwise you would be in big trouble if you had a flat.
Making a decision without following it with an action is still a fantasy. |
12-05-2010, 07:42 AM | #3 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Are you sure that they are saying per bolt, or is it per rim and the $20 is the unmount/remount/balance fee?
12-05-2010, 09:08 AM | #4 |
What CT said. Are you buying tires? If so, that should be included.
12-05-2010, 10:32 AM | #5 |
Drives: 2009 Yaris Onyx Join Date: Dec 2009
you've lost me here, so you don't have a jack or tire iron....check under the drivers seat....... If your in the Lansing area let me know.
12-05-2010, 08:56 PM | #6 |
Drives: 2008 HB, A/T, Power W/L/M Join Date: Oct 2008
Car comes with tire iron AND jack! Read your owners manual please!
Never take eyes off opponent - Bruce Lee |
12-21-2010, 09:02 AM | #7 |
Drives: 07 YARIS HATCH 5 DOOR Join Date: Apr 2007
the jack is under the driver's seat and the rest of the needed junk is in the trunk in a little black bag next to the spare tire...ehh I guess it's there..well I hope it's there in mine!
12-21-2010, 10:09 AM | #8 |
Drives: 07 Yaris Turbo Join Date: May 2007
I can't tell if the OP wants to rotate the wheels, or actually changes tires on wheels.
12-21-2010, 11:02 AM | #9 |
Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
If you bought the car used and the jack and iron are MIA, any 2-Ton trolley jack and a cross type tire iron with a 21mm socket (from a local auto parts store) will be sufficient for changing and rotating your wheels. (given that you have stock wheels and lugnuts)
Even though it is heavier than the scissors jack from Toyota, I prefer the stability of the trolley jack when changing wheels at home, and the cross type wrench allows me to put more torque on the lugs to get them off. If you want to spend less, goto a salvage yard for a Toyota scissors jack and lug wrench from most any of the economy models. (Yaris, Corolla, Tercel, Scion XB and XA) |
Tags |
help!, tire iron, tires |
Similar Threads | ||||
Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
'54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem | Lettuce | UK | 0 | 09-30-2010 06:21 AM |
i think i have a big problem | kustom play | Off-topic / Other Cars / Everything else Discussions | 40 | 05-15-2009 10:14 AM |
HELP!! HID problem | 07yaris_fe | General Yaris / Vitz Discussion | 2 | 11-20-2006 06:00 AM |
So how do you like the BIG SMILE on the 07 Sedan???? | Ziv | General Yaris / Vitz Discussion | 3 | 02-03-2006 11:12 AM |
