Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 12-14-2010, 04:40 AM   #1
worldnmypocket
Drives: Yaris Hatchback
FUEL CONSUMPTION IN UAE ROAD
Hi,
I own a Toyota Yaris HB 1.3 2010 model. Since I am logging the km details upon refuelling, I am able to determine the fuel consumption. I am perplexed to see that I am getting only less than 11 km per liter (9.1 liter per 100 km) in UAE Roads. Is that the same everyone else using the same car getting?
worldnmypocket is offline   Reply With Quote
Old 12-14-2010, 04:58 AM   #2
syntax
syntax's Avatar
Originally Posted by worldnmypocket View Post
Hi,
welcome to YWME worldnmypocket
here is the link on some of the info that you may need, contents are in english, some are in filipino, but you get the general idea.
HTH
http://www.yarisworld.com/forums/showthread.php?t=29018
Old 05-02-2011, 02:26 AM   #3
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
YWME, can you share your fuel consumptions here in Gulf? liters per 100KM? Rials per year..
ricepower is offline   Reply With Quote
Old 05-04-2011, 01:11 AM   #4
zsazsa zaturnnah
zsazsa zaturnnah's Avatar
Drives: 2010 Yaris YX
Why bother about fuel consumption when fuel is way cheaper than water here in the Middle East????
zsazsa zaturnnah is offline   Reply With Quote
Old 05-04-2011, 02:46 AM   #5
arthur morales
arthur morales's Avatar
Drives: Yaris "Lite Blue Fleet"
Send a message via Yahoo to arthur morales
Mine I have Yaris Y Fleet 1.3 engine and same thing what you did I am getting more than 10 Km per liter of Octane 95. By the way Octane 95 is SR 0.60 per liter. I am aware that gasoline in UAE is much expensive than here in KSA.
arthur morales is offline   Reply With Quote
Old 05-04-2011, 02:48 AM   #6
zsazsa zaturnnah
How come you use 95? Yaris should be fed with 91 octane gasoline only!?
Old 05-04-2011, 08:31 AM   #7
arthur morales
I have started since day 1 Octane 95 by mistake. I checked with Toyota people and they said there nothing wrong with using 95 but Yaris is pre-designed for 91. I have used 95 for five consecutive times and when I read that it is for 91 I changed from 95 to 91, there I noticed that for 91 it seems that i am going slower than when i use 95. From that time on I am using 95, which cost more more than Sr6 per tank load.
Kayaris, I stand to be corrected. Suggestions please.
Old 05-05-2011, 03:54 PM   #8
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
it is because 95 has higher octaine % than 91... you want to go faster? fill up with higher octaine %. take note filling up with higher octaine than the desired % will result to engine failure in the long run.
marble_bearing is offline   Reply With Quote
Old 05-04-2011, 08:45 AM   #9
arthur morales
thank you ricepower. So we have difference in UAE and here. Wordnmypocket did not mention what OCtane he is using.
Old 05-05-2011, 12:11 AM   #10
ricepower
ricepower's Avatar
Same here for me, I am getting poor acceleration or take off with 91 and also noticed my gas tank is more easy to drain..
I changed back to 95 as I am getting better engine response and more mileage..
Old 05-04-2011, 05:32 AM   #11
ricepower
ricepower's Avatar
@Zsacia, It's not about the price..Just to compare if our consumptions is normal as others.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
