Old 12-17-2010, 06:22 PM   #1
Evangelion335
Evangelion335's Avatar
Drives: Soon
Forgive me for i have sinned.
I accidentally hit and maintained 7k rpms for like 2 seconds. I wont get into the reason why hahahaha >.>.
Its a new car too and i felt so bad for fucking up so badly. How much damage did i do in reality? (i dont usually go above 3k/4k rpms daily - no point in lying about it)
Evangelion335 is offline   Reply With Quote
Old 12-17-2010, 06:34 PM   #2
Happy Little Pony
Drives: 2007 Yaris HB
For two seconds? One time only? On a warmed up engine? The answer should be none. Unless your car is behaving in some way that makes you suspect that something is wrong, I wouldn't worry about it.
Happy Little Pony is offline   Reply With Quote
Old 12-17-2010, 06:39 PM   #3
Evangelion335
Drives: Soon
yeah, all warm.
Part that bothers me though is everyone is telling me that shift limiter kicks in at 6.2 but i was clearly in the 7.1-7.2 range. What gives, am i a real life initial D?
Old 12-17-2010, 06:38 PM   #4
How did you manage to do that when fuel cut-off is at around 6450 rpm?
Old 12-17-2010, 06:51 PM   #5
2007yariz
Drives: Yaris sedan
Modern engines are designed to endure that, also you will never be able to reach redline. It stops at about 5800 RPM if your redline is 6000...
2007yariz is offline   Reply With Quote
Old 12-17-2010, 07:55 PM   #6
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
In motion or neutral?
Check out my Build thread:
Old 12-17-2010, 08:55 PM   #7
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Old 12-17-2010, 09:13 PM   #8
Evangelion335
Drives: Soon
Iin motion. i have a base model, maybe i didnt get a rev limiter?
Old 12-17-2010, 09:37 PM   #9
Flipper_1938
Old 12-17-2010, 11:04 PM   #10
Evangelion335
Drives: Soon
Originally Posted by Flipper_1938 View Post
I'm curious how you got it above the rev limiter....by any chance, did you downshift into too low of a gear?
was at a red light in 1st, happened as i was attempting to shift to 2nd.
Old 12-18-2010, 05:42 PM   #11
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
If you didn't then some of your engine parts would be scattered into orbit by now lol
I've done this a couple times with mine too in 1st and 2nd with no problems. Just don't plan on turning this into a habit.
Old 12-17-2010, 10:23 PM   #12
bxtech
Drives: 2007 Hatchback
Just out of curiosity......What makes you feel that you damaged the engine? Is it making some funny noises or something? Is it not running right now?
bxtech is offline   Reply With Quote
Old 12-18-2010, 07:06 AM   #13
Freedan
Drives: 2010 Yaris Bayou Blue 3DR Lift
Were you wearing platform boots when you did this? Just curious.
Freedan is offline   Reply With Quote
Old 12-18-2010, 07:32 PM   #14
nemelek
DWEED
nemelek's Avatar
How new is the car? If it has over 1,000 miles and was warmed up, I wouldn't worry too much.
Old 12-18-2010, 11:07 PM   #15
shinlee
shinlee's Avatar
Drives: 07 liftback
this has hopefully gotta be a joke thread.... cuz this might be one of the most retarded whines I've ever seen, lmao....
"OH NOES!!!! I HIT THE REV LIMITER AND IT BOUNCED OFF IT A FEW TIMES!!!!! MY CAR IS RUINED!!!"
i've bounced off the rev limiter countless times, as have MANY others on this forum, in 1st, 2nd, 3rd, and i've tried my damn hardest to get it to do the same in 4th, but the gov kicks in too soon.
Unless you sit there and just sit in your driveway and hold the gas on the floorboard for like 3 straight minutes, odds are, you won't damage anything. Hell, it's suggested to go through a full range of rpms during a break in period to just ensure everything settles in correctly.
shinlee is offline   Reply With Quote
Old 12-19-2010, 03:33 PM   #16
SilverBack
Joey
SilverBack's Avatar
I don't understand why your calling the OP a "retard" (who BTW is only trying to learn to play it safe) when you're over here purposely trying to hit the rev limiter for shits and giggles. Just to remind you, it's not a toy. It's there to help keep you from losing your engine in case you forget to shift in time. You should really think about how bad you're making yourself look before ripping on someone else. .02¢
Old 12-19-2010, 08:24 PM   #17
Kal-El
Kal-El's Avatar
Yeah know need to go negative on the OP. This is a legitimate question and concern.
A break in period is still a good process to take although it isn't nearly as important as on past cars. Today's cars can take far more abuse and are already built to much tighter tolerances that require little "settling" of engine components. Still, automakers recommend these break in periods that suggests limiting RPM, very high speed, jack rabbit starts, and long sustained speeds.
The OP has every right to wonder if he may have affected long term durability.
That said, I don't think there's anything to worry about from this example especially on a proven to be bullet proof engine. Today's cars are extremely resilient to abuse.
Check out these torture tests for Ford's new EcoBoost engine in the F-150.
And this is with no break in.
http://www.ford.com/trucks/f150/expe...9m2nop20101101
Old 12-22-2010, 09:39 PM   #18
gukin
Drives: '03 Focus SVT EAP
Don't get your underwear all in a bunch!
I drive a Focus SVT and the hard limit on revs is the oil pump disintegrating at 8000 RPMs, my redline (after an after market tune) is 7600 RPMs. I've bounced off the rev-limiter and there isn't much to worry about. Okay maybe you'll only get 999,750 miles out of your engine instead if the 1,000,000 you were hoping for.
Toyota (despite all the recalls and anti-Toyota rhetoric) builds damn fine engines, I'll bet there's some builders who have no trouble revving their engines to 9,000 for extended periods of time.
Enjoy your car, it will last longer than you'll want it (unlike my SVT)
gukin is offline   Reply With Quote
