Old 01-07-2011, 09:56 AM   #1
mrrock
Drives: yaris 2dr hatch
TRANSMISSION QUESTION - stick
I've noticed lately that when putting the car in first gear that it sort of snaps into gear rather than sliding into gear. Any way to correct this. are there any adjustments to the transmission
mrrock is offline   Reply With Quote
Old 01-10-2011, 05:18 PM   #2
Evangelion335
Evangelion335's Avatar
Drives: Soon
I know what youre talking about, i believe its that safty catch that makes it difficult to slide into first if youre above 20mph. Then again, ive had times where i KNOW my clutch was all the way out, and i still ground first (or what seemed to feel like it), i suspect its that safety mechanism.
Evangelion335 is offline   Reply With Quote
Old 01-10-2011, 05:27 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
you're in CT.. it's cold there right now. unless your transmission is warmed up, it's gonna be notchy as hell... does this happen all the time? or only when the trans is cold?
Old 01-10-2011, 06:01 PM   #4
SignPirate
SignPirate's Avatar
Drives: 2007 Blue Yaris
I live in So. Fla. every morning it seems to hesitate going into second gear. At 46000 I just changed the filter, fluid, and gasket still no change. I'm sure it's a warm up thing cause it doesn't do it after the first start up.
SignPirate is offline   Reply With Quote
Old 01-10-2011, 06:02 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
sounds like your syncro is taking a crap. very common in your transmission. have you adjusted your clutch?
your second gear problem has nothing to do with the 1st gear problem posted above.
Question for Transmission Cooler 33lam Australia 3 09-26-2010 10:54 PM
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 12:38 PM
Transmission Question buddyjim Performance Modifications 14 04-13-2010 05:00 PM
Automatic Transmission Question daf62757 New YARIS Purchase Forum 16 02-16-2009 10:41 PM
A question about the gas thingee -- the place where you stick the nozzle. petesimac General Yaris / Vitz Discussion 11 07-18-2007 08:23 PM
