![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
WTB: spacers and rear sway bar
hey, im planning to do some more mods to my yaris as soon as it warms up a bit.
i am looking for rear sway bar and spacers and a cheap cat back. also looking for a stock yaris alarm. the rear sway bar i am looking for either used or reasonable priced "like new," let me know what you got spacers, what ever size you have; let me know and how much you want for them. the main plan for these are to only offset the rears (2) but if i need to buy an entire set (4) then so be it. let me know what you got and how much. im looking for any bolt on mods.
spacers are usually sold in pairs, you should be ok there. If they are more than 5mm (meaning 10mm+), make sure they come with longer studs.
Check with thebarber. I know he's got a pair of 7mm spacers lying around. Don't know if he ever intends to use them. He has no extended studs but I have a NAPA part# for them.
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
wait what do the spacers actually do ? just let the wheels stick out from the body a little bit and where do they go ? between the inside of the wheel and the drum?
spacers either go between the hub and the wheel (front or rear) or behind the hub (rear only). they move the wheel out. This can improve the look (more flush with the fender) and/or handling (wider track or stance).
thanks
pretty self explanatory i guess hah |
![]() ![]() Drives: 08 yaris Join Date: Nov 2010
check craigslist i picked up a TRD rear sway for $50 a few weeks ago.
a link to search all post at once http://www.searchtempest.com |
toyota
I WANT SWAY BARS
| installing Penguin Garage rear hub spacers! | Tamago | DIY / Maintenance / Service | 101 | 05-21-2011 12:29 PM |
| Rear hub spacers | Stiv | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 03-01-2010 11:54 AM |
| question on Rear Hub Spacers | mastaofdisasta | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 02-02-2010 09:54 AM |
| Penguin Garage Rear Hub Spacers!! | Penguin Garage | Sponsors Classifieds Area | 92 | 09-02-2009 06:16 PM |
| Handling changes from rear hub spacers and minor concern. | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 07-10-2009 08:07 PM |
