![]() ![]() Drives: yaris sedan Join Date: Oct 2008
driver seat belt light
for some strange reason my seat belt light does not come on when the car is running and the seat belt unfasten. what can cause this?
About the only thing I can think of that could cause it is the 7.5A MET fuse being blown.
where is this fuse located?
In the fuse panel that is under the bottom of the dash by the hood release lever.
#6 | |
ok i now got chance to check the fuse. the fuse is good
OK. The driver's seat belt indicator gets driven by CAN bus message from the SRS ECU to the instrument cluster, so the easiest next step would be to swap your cluster with one from another car with a working indicator to verify that the issue is in the cluster.
ok thats going to be kinda hard. i will see what i can do. will let you know if i get it working
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 09:15 PM |
| Back Seat Removal... | Idjiit | DIY / Maintenance / Service | 87 | 02-08-2015 12:07 PM |
| DIY: Heated Seats for 2006-2011 Yaris | CTScott | DIY / Maintenance / Service | 24 | 11-04-2012 05:18 PM |
| Driver Seat Loose!! Help??!!! | mhkritzinger | DIY / Maintenance / Service | 12 | 01-16-2011 04:57 AM |
| Aftermarket Driver Seat Bracket | Wisher23 | Willing to Buy by private party | 1 | 03-24-2009 12:48 AM |
