that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
So here's the two problems. 1. I got my car out of the shop from hittin a pole bout month ago and the airbag light comes and stays on......could it be linked? the airbags did'nt go off or anything.
My other problem is with my lock/unlock switch on the door for all doors. It's been locking but not unlocking, never acted up before
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
For the airbag light, check this thread for instructions on how to read the error code:
http://www.yarisworld.com/forums/sho...d=1#post557473 For the door unlock issue, you'd need a voltmeter to test at various points, starting with the connector on the bottom of the switch assembly, to see where the problem lies.
I'm thinkin I got a short somewhere......bc sometimes it'll act up sometimes it don't today it was workin perfect
Shorts cause fuses to blow or make fire. If it's intermittent, then it is more likely a loose connection.
also I have access to a dianostic tool could that tell me what's up with the light?
| Yaris problems and solution | ubospawis | Middle East | 26 | 01-12-2011 03:41 AM |
| A few problems | drunkwithwords | General Yaris / Vitz Discussion | 1 | 04-01-2010 11:13 AM |
| new user with a couple of problems | grant_nelton | Great Lakes | 8 | 03-13-2009 10:18 PM |
| Problems? | Twistoffate0817 | General Yaris / Vitz Discussion | 35 | 12-24-2008 11:53 AM |
| Timing chain, sprockets, & cam position sensor problems? | PetersRedYaris | DIY / Maintenance / Service | 8 | 01-04-2007 11:50 AM |
