![]() Drives: 2010 Yaris Sedan Join Date: Apr 2011
Yaris wheel and vibrations
Hi guys, I just got a new 2010 yaris sedan and I am loving it, but there's a couple of small problems that I don't know if its normal or not. I really don't know much about cars
![]() To drive straight, I need to turn the wheel just slightly to the right, around a couple of degrees or so. I checked the tire pressure and it was fine. At high speeds there isn't any strange vibrations or anything so I think the alignment is okay. Is this normal? Or should I take it in to be looked at. Another small gripe is that when I stop at the stop light, I can feel the engine vibrating through my seats and steering wheel. Sometimes its stronger sometimes its not as bad, and as soon as I accelerate, the vibration is gone. I know all cars vibrate somewhat, but its a lot stronger than I am used to. Is this normal to Yarises? Thanks for any help! Other than this, I love my new yaris! |
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
Bad alignment doesn't always cause vibration, eg camber/caster. Vibration in the seats? That sounds excessive, but some people are more sensitive than others, so I can't say. Best to have a mechanic/car guru/technician/dealer look at that.
The best modification you can make is between the steering wheel and driver's seat. |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I had a similar issue with the steering wheel being slightly off center/having to hold constant left, after I drove off the road in seasons first snowfall... Getting an alignment completely resolved the issue.
Vibrations at idle is... excessive but normal. |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I don't have either of those issues.
Making a decision without following it with an action is still a fantasy. |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
Mine has pulled to the left since I bought it but I've chosen to ignore it for now since my plan is to lower the car in the near future. Tires aren't showing any accelerated or weird wear patterns so I am not concerned...
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
Both issues are normal. As stated above, you can do an alignment for the drifting but I wouldn't bother unless it gets considerably worse. As for the vibrations, they are normal for the Yaris.
Tantum religio potuit suadere malorum. |
I've only noticed a very slight vibration when the A/C clutch engages. Man, either you guys are all supersensitive (or I'm not sensitive at all) or you guys got a bad batch. I can barely tell my car is running when it's on and idling. Maybe it's automatic tranny thing (I've got a 5spd). I dunno. I can definitely say that's not the case for many other cars I've been (friends' pick-ups, ie hilux, mitsu, nissan, also some older Corolla's, Nissan Sunny). At idle, the Yaris is nearly as smooth as my old Lexus V8. Rev it up and it's a completely different story.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
We have the vibration for the '08 sedan and '10 3 door with the auto tranny . The vibration is stronger for the '08 sedan when stopped for red light or idling . Seems to be a little stronger since the head cylinder gasket replacement . Took it to a TOYO service center due to the rough idle after the H.C.G. replacement . The spark plugs were checked under warranty and tech showed them to us . Looked to be in good condition . He stated it's normal for the V.V.T.I.
. We wanted them replaced under warranty , but were denied . Still shakes to the point you can feel it through the seats . Does help with relieving some stress from drivers fatigue . .
Thanks for the tips guys :) Yaris world rocks! The vibrations I'm getting used to, its not too bad. I guess its standard on all automatics.
Do you guys know if the alignment would be covered under warranty? The tilt is very slight and I don't want to spent lots of money fixing it. |
I forget what it's called, but this can be adjusted with an alignment too (or it's supposed to be). It's something like dead zero, or heck. . . I wish my memory was better. Basically steering wheels are just bolted onto a steering column. You could attach the wheel upside down or rotate it 90degrees if you so wanted. But so long as your alignment is good and your frame isn't crooked, you COULD just adjust that. Should be just a few bolts behind the airbag. . . then again I haven't done this on a Yaris, so I wouldn't know for sure, but it was definitely the case with my other cars.
If the car tracks straight but the steering wheel is cocked then it could be the steering wheel is mis-aligned. It could also be the rack was not centered. If the car actually pulls one way or another, your alignment is probably off, usually the caster.
Having said all that, it should be covered under warranty. Take it to your dealer if it bothers you. |
![]() Drives: 2010 Yaris Sedan x 2 Join Date: Sep 2006
Alignments are covered under the bumper to bumper? Really? Anyone had an alignment done under the bumper to bumper?
#13 | |
Since you only bought the car a few days ago, just take it back to the dealer. It really falls under "dealer good will to keep the customer happy" than under the bumper-to-bumper warranty. If you wait too long, they may say it is not covered... |
#14 |
![]() Drives: 07 sedan.04 2500hd,10 mazda3 Join Date: Apr 2011
#15 |
I paid $75 at pep boys. They showed me a computer print of before and after. Spark plugs are only $30. Why bother with the dealership...
Also, the vibrations went away for me with a spark plug change. At idle, I can't tell if the engine is running without testing the pedal. |
#16 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
My auto vibrates some when I'm stopped and in drive, in which case the engine is under load. When I pop it into N it's ultra smooth.
#17 |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
I get more vibration than any of you cause im a ricer
#18 |
![]() ![]() Drives: 07 lb jeep tj Join Date: Oct 2010
Mine use to vibrate when I got it but I adjusted the idle screw on the tb (do not recommend doing this) and the idle is very smooth now idles at about 750-800 now.
