Old 04-09-2011, 02:06 PM   #1
end user
GRO H2O
Drives: Yaris
Super quiet exhaust.
Looking for after market exhaust that is as quiet as the stock exhaust. No fart actions. Any suggestions?
end user is offline   Reply With Quote
Old 04-09-2011, 02:08 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
the TRD jdm version s muffler i have is QUIET and looks stock without the big gaudy tip....
Old 04-09-2011, 02:08 PM   #3
"As quiet" means just as restrictive. Even the TRD axle-back is a little louder than stock.
What is your reason for wanting an aftermarket exhaust?
Old 04-09-2011, 02:21 PM   #4
end user
GRO H2O
Drives: Yaris
Free up the flow and maybe gain a tiny bit of power. I'll slowly keep on adding performance tid bits over the next year. If I can get 15hp more I'm good but don't want to sound like a wanna be race car.
Old 04-09-2011, 10:44 PM   #5
tk-421
tk-421's Avatar
Drives: 5D-07-LB
While I agree with this statement, some aftermarket exhausts do get closer to others as far as volume levels. I've read that the Fujitsubo Wagolis is a good example of the quieter sort... also listened to a couple of youtubes.
Old 04-09-2011, 04:42 PM   #6
severous01
any aftermarket exhaust will be louder. if you go custom with magnaflow muffler it should be quiet until about 3 grand on the tach and then start getting louder....but it's not loud. it's a nice low sound. it will resonate, but i dont have that exhaust yet so i cant tell you it's resonant rpm range.
http://www.magnaflow.com/02product/streetmufflers.asp
14807 for round tips and 14833 for square tips. these are the mufflers i'll be using with a custom catback pipe. removing the resonator will make it louder, and also a header will make it loud. keep the resonator and go axle back for a quiet exhaust, but it's got more restrictions.
Old 04-09-2011, 05:00 PM   #7
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
Nothing is as quiet as the stock exhaust (echo)
weedtank is offline   Reply With Quote
Old 04-09-2011, 05:45 PM   #8
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
i'd have to suggest the muffler i have: Dynomax Super Turbo muffler. If you plan on keeping your cats, then this thing would be perfect.
Old 04-11-2011, 11:29 PM   #9
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
i agree with peter! i am running a dynomax 2" cat-back with 2 1/2" tip looks stock and not to loud. also running a meagan header!
"who the cap fit let them wear it"
20104dr is offline   Reply With Quote
Old 04-12-2011, 12:38 AM   #10
matthewai
matthewai's Avatar
Drives: it is kinda stock
so this one fits the 2010 sedan ? and still get a louder sound then the stock sewing machine sound ?
Old 04-12-2011, 12:50 AM   #11
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
its a universal muffler, so u need to have the shop bend the 2" pipe cat back and do some manuvering of muffler to fit. but i got it to work. actually my muffler is a 2 1/4" in n out. the guy a muffler shop told me that 2 1/4" was to big lossing too much backpressure. i say if u want a lil better flow get a bigger than stock universal replacement muffler with piping!!
Old 04-09-2011, 07:31 PM   #12
You can't free up the flow AND have it as quiet at stock.
You won't; maybe 5 at best.
Old 04-09-2011, 07:45 PM   #13
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
You could mimick the stock multi-pass set up by using two or three high performance mufflers. I'm not sure how many mufflers you can cram in the stock location, but going through three large diameter turbo mufflers might be pretty quiet. Rearward through the first, forward through the second, rearward through the third.
Old 04-09-2011, 09:04 PM   #14
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Even the TRD Exhaust system is loud.
Old 04-09-2011, 09:09 PM   #15
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I am looking for something similar, but I want it to be just a hair louder than stock. I had a random turbo muffler on a civic and liked the way it sounded, just the slightest bit of increase in sound and no resonance...I'm just not sure it will be exactly the same on the Yaris so i haven't pulled the trigger.
Old 04-09-2011, 10:29 PM   #16
Freedan
Drives: 2010 Yaris Bayou Blue 3DR Lift
I love my Tanabe Touring Medalion. Just the right amount of pep when I'm accelerating and stays nice and quiet when I'm not.
Freedan is offline   Reply With Quote
Old 04-14-2011, 12:06 AM   #17
R2D2
Crazy Oil Sniffer
R2D2's Avatar
+1. Good sounding exhaust without being too loud with a nice, deep tone. Built like a brick outhouse, too.
-The Fitful One
Old 04-09-2011, 10:52 PM   #18
Plus the +15 hp. Sorry, but no.
Quiet Aftermarket Exhaust?? darkMINI Performance Modifications 30 01-21-2011 10:26 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
anyone use Dynamat/ Be Quiet to deaden exhaust noise? Galavoxx Performance Modifications 9 11-29-2006 04:28 AM
