Old 04-28-2006, 12:24 PM   #1
Goose
Car Geek
Drives: Yaris Liftback
Unbelievable... my Yaris showed up!
Well, 2 1/2 weeks after I placed my order, the dealer called and said that my Blazing Blue liftback has arrived! Thank goodness. Hopefully I can pick it up tomorrow.
I'll be sure to post pictures, although it won't be anything exciting yet. Spec is (as far as I know) the Convenience Package with 15" steelies. I'm probably going to drive it for a while before I start to do some basic OEM-type mods, such as the TRD suspension. I might even get raped for the tasty 18" TRD wheels -- they do look nice.
Can't get ahead of myself, though. Anybody care to speculate on what kind of impact wheels/tires like 18's would have on mileage?
Kevin
'07 Blazing Blue 5-speed liftback (sold)
'08 Black auto liftback (sold)
'09 Carmine Red auto 4-door liftback (sold)
Goose is offline   Reply With Quote
Old 04-28-2006, 12:44 PM   #2
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
congrats goose!
as far as the big wheels effect on fuel economy, would i be right in thinking that they would require more power to get going? if so, would it be a noticeable difference in fuel consumption (and acceleration time?)
stuffy is offline   Reply With Quote
Old 04-28-2006, 10:41 PM   #3
AutoTech1
Drives: None yet
Originally Posted by stuffy
congrats goose!
Think of it like this. Remember that BMX bike you use to ride? Well remember how easy it was to get going fast? It required less energy to turn the wheel as well, because the wheel was smalll. Then you went to that mountain bike. The wheels were larger. It required a bit more energy to rotate that wheel... Getting wheels that are larger can throw off you readings for mph slightly as well as fuel economy... It shouldn't be too noticeable though.
AutoTech1 is offline   Reply With Quote
Old 04-28-2006, 12:44 PM   #4
ricko
ricko's Avatar
Drives: Copper-Orange Yaris RS
Congrats. The 18's will improve gas mileage somewhat, but I think the real benefits lie elsewhere.
ricko is offline   Reply With Quote
Old 04-28-2006, 12:45 PM   #5
stuffy
stuffy's Avatar
improve? i would have thought they would have the opposite effect
Old 04-28-2006, 12:45 PM   #6
ricko
ricko's Avatar
The 18's will require LESS power to get going, due to less weight.
Old 04-28-2006, 01:24 PM   #7
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
Ummm, no. The 18" rims will be significantly heavier than the stock rims. The difference in tire weight will not balance that out.
Idjiit is offline   Reply With Quote
Old 04-28-2006, 10:46 PM   #8
AutoTech1
Drives: None yet
They are more likely to wieght more... Even if they are light wieght wieght wheel... Just because they are bigger...
Old 04-28-2006, 12:47 PM   #9
ricko
ricko's Avatar
Remember 18'' alloy wheels have less rubber, and the wheels themselves are significantly lighter than the steelies.
Old 04-28-2006, 10:48 PM   #10
AutoTech1
Drives: None yet
But the "steelies are smaller." The 18's are larger... The only gain I can see for getting 18 is the less rubber. You corner better... But you increase the chance or rolling the tire off the wheel under hard cornering...
Old 04-28-2006, 01:10 PM   #11
stuffy
stuffy's Avatar
ahh, i see, i was thinking by just being bigger that they would require more energy to get going, which would probably be the case if the weight were the same
but i'm no physicist, so i could be wrong on that one
Old 04-28-2006, 01:31 PM   #12
Idjiit
5 Stars, Bitches
You are correct. Even if the wheels are the same weight, if the wheels is a larger diameter more weight is further away from the axel, which takes more energy for the car to move. Needless to say, the heavier the wheel, the bigger this problem becomes.
Old 04-28-2006, 01:38 PM   #13
Idjiit
5 Stars, Bitches
Here's some sample numbers -
Yaris 15" Steel Wheel/Tire Combo - 37lbs (17lb wheel, 20lb tire)
Toyo Proxes 4 Ultra-High Performance Tires with light Rota SubZero Wheels:
15x6.5 w/ 195/50R15 - 29lbs (12lb wheel, 17lb tire)
18x7.5 w/ 215/35R18 - 39lbs (19lb wheel, 20lb tire)
So, even with a lightweight 18" setup, you're both heavier than stock and a lot of that weight has been moved further away from the axel, so you'll definitely see a drop in performance.
Old 04-28-2006, 10:50 PM   #14
AutoTech1
Drives: None yet
Great point. I didn't see you wrote that, else, I wouldn't have posted what I posted before this. But you still explained better than me.
Old 04-28-2006, 02:42 PM   #15
Ziv
It's all about VVTI
Ziv's Avatar
Drives: Yaris 5Dr LE White
hum...... tell me if I am dumb. Is that mean bigger wheel is not as fuel consuming?
I know a few basic, the smaller the wheel obviously will have more power to go up the hill and stuff, the bigger the wheel will have better performance. Right?
I am getting confuse.
Oops, sorry where are my manners, Congrats, Goose!
Ziv on Vitz '06.
Ziv is offline   Reply With Quote
Old 04-28-2006, 03:03 PM   #16
Idjiit
5 Stars, Bitches
Err... you mean, will you get worse mileage with a bigger wheel? You'll definitely get worse mileage with a larger wheel, all else being equal. The car has to work harder to turn the wheel, not sure why this is a difficult concept to grasp.
It depends on what you're defining as "performance". The smaller wheel will have less rotantional mass, which will allow the car to move quicker (assuming the traction is there). But in terms of cornering, the small wheel with larger sidewalls may not have as much grip so having a larger wheel with shorter, stiffer sidewalls will be better.
The best option will be the wheel that gives the best balance between weight and cornering stability. That certainly isn't the 18" option - I would say if you're performance-minded a 16" wheel with a good performance tire would be the best compromise.
Old 04-28-2006, 03:11 PM   #17
ricko
ricko's Avatar
I had NO idea the 18's would be THAT heavy. I just know the 16" alloy on my Acura was significantly lighter than 15" winter wheel, and they were only Honda alloys. The extra weight must come from the added width of the tire???? In Canada the 15 inch wheels come with 185/60 tires. How does the rolling diameter compare to that of the 215/35/18's.
Old 04-28-2006, 03:32 PM   #18
Goose
Car Geek
Actually, my first reaction to larger wheels/tires was the effect of the larger contact patch on rolling resistance. Most high-mileage cars are concerned with low rolling resistance, and therefore use skinny, harder compound tires to maximize this benefit. By going to an 18" wheel (with probably at least a 7" width) and similar tires, there's a lot more rubber in touch with the road; contrast this with a 6" or 6.5" wide steel wheel and 185/60 tires, and I assume the performace combo isn't gonna want to roll as easily by comparison.
I assume there's a rolling resistance calculator floating around the 'net somewhere. Just gotta find it.
Kevin
Power-to-Weight Ratios of Yaris, Fit, Mini, etc. Idjiit Off-topic / Other Cars / Everything else Discussions 6 10-06-2017 05:10 PM
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
