![]() ![]() ![]() Drives: Yaris Hatchback Join Date: Apr 2007
Speed needle
Ok, so I changed the speedometer color and everything went fine. I put it all back together and put the speed needle back and fixed it to 0 and when I turned the car on it went below 0. Next I tried to take the faceplate off and turn it on and change the below 0 to 0 so it stayed put. I drove a bit and after called it a day. Next morning the needle was back to below 0 so what i did was push it in harder and drove around and it would not move at all. Stuck on 0. Now I loosened it up again and again put it to 0 and later went out to check and again. Below 0. Hope I'm making sense here. Any help would be appreciated. Sorry for typos. Typing from iphone
![]() Drives: 2007 Ghetto VITZ Join Date: Aug 2007
U broke it. Lol
i hope not. Right now its sitting at below 0. So it still moves when i accelerate, just about 10 miles behind
I hope i can help but thats one of the things i dont mess wid in the car.
Good luck fixin it. |
anyone else?
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
just put a [-10] behind every number
I suggest taking the front cover off, and then adjusting it after turning on the ignition.
^ Thats exactly what i did. It was below 0 and i took the cover off and turned the car on, moved it to exactly 0 and drove around. Worked perfect. I put the cover back on and got in the car the next morning and it was back to below 0.
Does it seem like the needle's tube is slipping?
not really. At first when i moved it, the needle felt loose, but i turned car on and it felt some resistance so i moved it to 0. now i pushed it in more and it never moved up or down, just stuck on 0. So i loosened it up some but after i drive and leave the car it just falls below 0
#11 | |
#12 | |
ヤリスワールド
Drives: 2008 HB Join Date: May 2010
Ok. I'll try that then. Thanks
#14 |
Just got back and it worked, thanks CTScott
#15 |
I had that same problem when I did my LED change, though mine eventually corrected itself back to 0, but now I have the issue if i accelerate too fast the needle gets stuck at 60.
#16 |
mine was getting stuck at around 40ish, i retried what CTScott said and eventually it worked and just kept going to whatever speed i was going without getting stuck
| ABS and "!" lights are ON again! | onizuka | Canada | 457 | 04-28-2023 09:40 AM |
| !! Speedometer Needle Problem !!! | Murtaza_murti | Cosmetic Modifications (Exterior/Interior) | 40 | 11-25-2014 10:48 AM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
| Six speed | Snyprwlf47 | Performance Modifications | 16 | 11-24-2008 09:04 PM |
