![]() ![]() Drives: toyota yaris sedan Join Date: Sep 2010
Horn upgrade
Hi
Will this toyota camry 2007+ Horn Part#86510-AA010 fit on my 2007 Toyota Yaris Sedan version ? Will it be a plug and play ? Is there place where i could hear how it sounds or can someone tell me if it sounds something like the Toyota premium Horn ? |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
That looks like half a premium horn set (usually a dual hi/low configuration) And the bracket looks right for our car. Not sure of the plug ...cant be that different though. If you wondering about plug and play, I have to ask....you do realize your going to have to take off the whole front bumper area to do this dont you?
I have the Part number for the low note horn but I didnt put it
Yes I do realize that I have to take off the hole bumper already did that When you get the answer for the plug and play can you let me know |
Well the connector is the same, but realize the yaris has only one horn, so if you get two you will need to either get another connector of figure it on you own. Maybe get another from a junk yard or ebay.
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
It is more expensive but just get the premium horn kit. There is a kit that contains the necessary Y-cable to attach both horns to our car. I bought this kit some weeks ago and it is absolutely plug 'n play.
I bought it from this guy: http://cgi.ebay.com/ebaymotors/JDM-T...Q5fAccessories I can recommend him, received my kit in only 4 days from Japan to Germany. |
#7 | |
![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
I didn't even have to remove the bumper. Just popped out the top pins and pulled the front assembly forward to get my hands in. |
#8 | |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
quite a bit more. JDMpit had an e-Bay auction which was about the same price, so I just ordered from their website. It took longer than 4 days for some reason. I'm pretty sure I paid less than the current price. http://www.jdmpit.com/jstore/product...roducts_id=279 So again, that e-Bay price is pretty good. |
#9 | |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
The kit is complete; it includes the "Y" connector with the correct OEM connectors as well as a grounding wire and even the nut/bolt for the second horn. |
toyota
i had mine for a year now dual horn and i think ive used it less than 10x... should have went with bull horn instead..lol
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
Thanks alot guys
![]() Drives: 2014 Yaris lb 1.33L Join Date: Apr 2011
how does it sound?
the link that ebay guy provided for the premium horn is not available....... |
#13 | |
At the end. |
#14 |
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
i have these
post #33 has a video/sound clip i didnt use the rely either i put both pics but they now are red side facing out (second pic obvi) it looks way better than when i first got them in |
#15 |
thx a lot
#16 |
i got mine for like 23 dollars and i think it sounds better and looks better with the red showing through the grill than the toyota one just my o-pin
#17 |
The Hella Twin Tone sounds like the Premium ones. I can't hear any difference. It is red, not plug 'n play and cheaper. Thats all.
#18 |
its not to hard to wire them up though
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| My horn install... | Goose | DIY / Maintenance / Service | 7 | 01-29-2016 04:10 PM |
| Horn Relay? | MGargano | DIY / Maintenance / Service | 7 | 11-14-2009 06:01 PM |
| HELP! SRS light won't go off, horn doesn't work | kudzu71 | DIY / Maintenance / Service | 11 | 08-18-2009 05:12 PM |
| Toyota Premium Horn | Meteorite_Marty | Cosmetic Modifications (Exterior/Interior) | 22 | 02-18-2009 11:28 PM |
