Old 05-20-2011, 12:51 PM   #1
sg11
Drives: 2010 Liftback
tire pressure sensors
I remember reading on here someone saying that the tire pressure sensors used on the factory steel wheels are different than the ones used with the factory alloy wheels? Is this true?
sg11 is offline   Reply With Quote
Old 05-20-2011, 12:54 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
NO.
Old 05-30-2011, 07:54 PM   #3
dzcab
Drives: 2011 3Dr Hatch
Can they be taken off factory steel wheels and put on aftermarket wheels?
dzcab is offline   Reply With Quote
Old 05-31-2011, 12:08 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
From what I understand, the Yaris' TPS isn't in the tire. Check out the details here: http://en.wikipedia.org/wiki/Tire-pr...ystem#Indirect
Old 05-31-2011, 12:16 PM   #5
Yaristeve
Drives: 3-door hatch
The (2011) Yaris TPMS is part of the valve stem so they are inside the tire. They can be moved from the steel wheels to alloy wheels. I had it done when I had my steelies replaced with the Scion 7-spokes on my Yaris.
Old 05-31-2011, 02:37 PM   #6
CrankyOldMan
I stand corrected. I was assuming that a direct system would be more expensive, and therefore not found on an econo-box. I even went and found confirmation, with pretty pictures: http://www.toyotatpms.com/
Old 05-31-2011, 04:46 PM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i swapped my sensors off my steelies to my rota's. They fit fine.
Old 05-31-2011, 06:32 PM   #8
kimona
kimona's Avatar
The TPMS from your Toyota steel wheels can be swapped into just about every aftermarket wheel.
Old 06-01-2011, 09:24 PM   #9
thepartsmancometh
Drives: '08 LB, '07 WRX
All cars sold in the US now must have direct TP monitoring. That's what ford told us internally (after all, it was the explorer incidents with Firestone tires that started this whole thing)
thepartsmancometh is offline   Reply With Quote
Tire pressure sensors Yaris2go Great Lakes 4 03-19-2012 08:04 AM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Tire Pressure Monitor Sensors....? 09TRD Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-19-2008 09:25 PM
